Sponsored by: Real Truck
trans conversion
Old Jul 25, 2010 | 07:07 PM
24Vford's Avatar
24Vford
trans conversion
has anyone swapped in a eaton fuller 10 13 15 or even an 18 speed if so what trans did you use i will not be adapting it to the 6.0 thats in the truck now.
Old Jul 25, 2010 | 07:54 PM
redford's Avatar
redford
FTE Leadership Emeritus
You mean like a Road Ranger?
Anything is possible, but why would you want to?
Old Jul 25, 2010 | 08:12 PM
24Vford's Avatar
24Vford
Yes like a road ranger cause i want to run alot taller gear for interstate driveing an it would be pretty sweet also so i say why not ha ha
Old Jul 25, 2010 | 09:05 PM
redford's Avatar
redford
The conversion would take some engineering. First, you would need to adapt the transmission and bellhousing to the engine, then figure out the clutch.flywheel interface. Next, you'd need to engineer the shifter, then figure out how to install a transfer case (probably a divorced case).
An easier solution would be a Gear Vendors overdrive unit. That would the number of gears you have to select from and give you a deeper overdrive. In the long run it would probably cost less.
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
Old Jul 25, 2010 | 09:23 PM
rbaker6336's Avatar
rbaker6336
You would have to go with a double overdrive in a 13 or 15 speed to get a taller gear that would be a .62 think the tallest of the rest is .73 which is lower than a ZF6.With more than double the weight and over 30" in length.Seems just the width would propose a pretty fair problem
Old Jul 26, 2010 | 09:27 PM
24Vford's Avatar
24Vford
i wont have to worry about it adapting to the 6.0 cause im not useing it an plan on useing a np205 divorced transfer case
i thought with that have 10 or 13 sped i can run a very tall gear cause the avalibility of gears
so any recomdations on which one
Old Jul 26, 2010 | 10:13 PM
rbaker6336's Avatar
rbaker6336
I would probably build a hybrid.Front section of a RTO9509 and rear section from an RTO9513
With a Roadranger trans and a divorced transfer you gonna have one long front drive shaft
You will also need atleast a 4" body lift for the trans to clear the floor
Trans50
New Member Introductions
Nov 20, 2013 02:09 PM
minishtr
Feb 27, 2004 06:54 AM
Jermafenser
Jul 10, 2002 11:29 PM
garyh
All Things Towing
May 28, 2002 07:20 PM
Maniak
Aug 31, 1999 08:05 AM
