trans. cooling
Old Apr 29, 2002 | 10:21 PM
garyh's Avatar
garyh
trans. cooling
Old May 19, 2002 | 02:44 PM
n2racin's Avatar
n2racin
trans. cooling
Hello. I just purchased a 01 EX. 4.6L. I was wondering if i needed a trans. cooling system. I am only going to tow my 74 beetle on occasion, and only short distances. Thanks for your help.
Old May 19, 2002 | 07:25 PM
Bryan's Avatar
Bryan
trans. cooling
n2racin,
I'd highly recommend adding a tranny cooler if your rig only has the one that's part of the radiator. My 94 E-150 ate 2 E4OD trannies on it's way to 80K miles, the first at dealer expense, the second at mine. The stock Ford cooler isn't big enough and the trans costs $2000+ to replace. I added a 4 row radiator, a 24K gross weight trans cooler(the biggest I could find) a temp gauge, and a TransGo shift kit. 65K miles later the trans hasn't skipped a beat and the trans temp has never been above 220deg (hit 220 once going from Utah to Colorado over the pass - total vehicle/trailer weight was 12,500lbs). Towing my 69GT350 (5200# w/trailer) it usually stays right at 180-200 deg. Add the cooler - you and your wallet will be glad you did!
My two cents,
Bryan:-)
Old May 19, 2002 | 11:15 PM
n2racin's Avatar
n2racin
trans. cooling
Thanks. I think you are right. It's better to play it safe. Anyway adding the extra cooling couldn't hurt. Thanks again.
Old May 28, 2002 | 07:20 PM
Gary E K's Avatar
Gary E K
trans. cooling
Gary's 99 V10
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4669&.jpg
cant go wrong with a big cooler,
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4518&.jpg
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
