Shopping for a lift kit - '06 F250 6.0L 4WD
I'm shopping around for a lift kit so that I can put some bigger tires under my truck. I came across a kit from "Ready Lift" that's half the price of any other kit out there. Has anyone here installed one of these kits? What do you think of it?
Here's a link to the kit I'm looking at http://www.ultimateautoaccessories.c.../LKS/69-2517CP
Got pictures of your finished product?
Thanks!
Thanks!
I wouldn't waiste my time with that kit. I just put a Fabtech 4 inch lift on my 01 2wd F250. You get what you pay for. Spend a little more money and do it right. Here is a link for you to check out.
6" Basic System w/ Performance Shocks - 2005-07 Ford F250 4WD w/o Factory Overload 4WD
You found a basic top hat spacer/rear block/ trac bar relocation kit. It'll work for what it says it'll do, which is give you a 2" lift. You'll clear 34s, maybe 35s with the right backspacing on the wheels, but you won't fit 37s with that kit.
I used a BDS 2" lower spacer, no trac bar bracket, and stock f350 blocks on my truck. Total cost was about $350 with only front shocks.
When it comes to coil spacers, they're all basically identical. When you start talking replacement springs, money talks and you get what you pay for.
What are your exact goals for the truck? Tire size, a stuffed look or suspension travel. Looks or performance, etc.
I don't know what wheel/tire combination yet. I see you're using Nitto Grapplers. I've been looking at those as well.
What stock size of tires did you have? I had 265/70R17s and they looked like golf cart tires under a SD. You could just stuff in a 33-34" tire and it'll fill the wheel well up fine, especially if you have 17" or 18" rims, and there's no lift needed. If you decide to go with a 2" kit, you're gonna want at least 35s to fill in the wheel well, otherwise you're back to square one with having a void you don't want. The problem with going over a 35" tire is that once you start talking tires that are 12.5" wide or wider, factory wheels go out of the picture in a hurry, and new wheels significantly add to the cost of lifting the truck (like doubling the cost of simply leveling it).
Don't buy the Trail grapplers if you want to tow anything at all, they're burning fast just under the weight of the truck. Nittos are notorious for short tread life (even though some guys will swear they get 60k out of a set), but really, any true MT tire that spends its life on pavement under an 8000# truck won't last long.
THANK YOU!!!! I have been on the fence about these tires and I love the look of them and the sizes available but am familiar with Nittos rep as far as wear goes.
Thanks for your help!
Originally Posted by allingeneral
A good thought that I have been considering. I was actually considering some LT285/75R17 tires for this application. They're about 33.8 inches in diameter.
Thanks for the feedback on the Nitto tires. This information makes me begin to lean toward more of an LT street tread instead of the more aggressive MT tread.
There are some nice looking MTs from Toyo and Mickey Thompson that are almost like A/T tires, and ProComp's Xtreme A/Ts are almost an MT tire. You should look at ProComps Xtreme A/Ts or M/Ts, I had the A/Ts once and really liked them.
FordOwnerJoey
01-31-2012 06:24 PM
