Agree with Krewat. Propane isn't going to give you any more power. If you for some reason do change to propane make sure you have hardened valve seats installed.
Originally Posted by Krewat
Propane on a gas engine isn't going to give you anything extra, in fact if the engine isn't setup for it (higher compression) it'll be worse.
Agreed.. on higher compression necessity as propane normally gives about 12- 15 percent less power at same compression ratios
I have a 1994 Ford F900 propane parts truck( which coincidentally was a propane tank truck). It has an Impco right from Ford.. Ford logos all over the Impco conversion.. I am thinking of using it in my 79 fire engine project.. but I will be making the engine new and higher compression if I do use the setup. Aftermarket Impco conversions are possible but they are difficult to do correctly and sanitary as they are add-ons and normally universal kits based on cubic inch.. I dont think I could make it cleaner than FORD.. this truck has all commercial stuff.. air cleaners/brackets, braided lines.. sensors and hard lines for heating/cooling the propane etc etc etc.. it would be pretty hard to replicate cleanly and as completely as the Ford engineers did from the factory
