propane system
Old Feb 21, 2008 | 08:36 AM
phatkat's Avatar
phatkat
propane system
does anybody runing a propane fuel system if so what kind of milage do you get.
Old Feb 21, 2008 | 11:32 AM
starwriter's Avatar
starwriter
You will get on average about 3mpg less then if you were running gasoline. Propane has a lower BTU and because of that your mpg drops by about 10-20% when you do the switchover. It depends on a lot of things like compression, type of engine, type of propane injection system, etc.
The advantage is that propane in most places is cheaper; however it needs to be 10-20% cheaper to just break even. I have thought about it as well, the cost is prohibitive for me at the moment. Other disadvantages are that even with hardened valve seats it will wear out your seats a lot faster. So figure an engine rebuild every 100,000 miles or so. However in the interim you will be doing fewer oil changes.
Old Feb 21, 2008 | 02:01 PM
masterbeavis's Avatar
masterbeavis
I have heard that propane motors had twice the life expectancy of the same engine running on gasoline? I have also heard that the fuel economy will be same or slightly less on flat ground, but will really decrease in the hills. Propane is getting stupid expensive now, I would rather run gasoline. I used to want a diesel rig but now with the cost of that fuel staying outrageous, I dont want one now either.
jbmoi
Modular V10 (6.8l)
20
Jul 27, 2019 05:17 AM
rempel429
Nov 20, 2015 05:46 AM
JackErnie
Jul 25, 2015 09:55 AM
Heatnbeat
Apr 23, 2010 06:58 AM
BBF250
Sep 22, 2005 09:44 PM
