Power brake booster or not?
I am a booster supporter.. many think you don't need them.. whatever..
I found my booster on ebay. watched a couple months, then found a deal..
mount? they have 4 bolts that go thru the firewall, or whatever u want to hang it on.. where do you want the booster to go? firewall, under floor.. never under dash I learned (brake fluid and carpet never go together)..
Sam
Sam
ebay.. search on "dual chrome booster" ( I wanted chrome for the engine bay)..
here is the booster, master and pedal assembly
http://cgi.ebay.com/ebaymotors/1953-...item4cec978b1c
Sam
Sam
I like power brakes myself. I got mine from CPP.....firewall mounted master/booster/pedal assembly. Another benefit of going this way is that the bracket mounts between the dash and firewall and, along with the steering column, it triangulates and strengthens the entire area. I used the top of the bracket (behind and underneath the dash now) to mount my SPW wiper motor by using it as a base for a weldod on custom bracket to bolt the motor onto. You can also get rid of another hole in the floor this way (the stock brake pedal hole). Just my .02. Regards.
Uni Moe
10-08-2014 08:21 PM
craftsmangary
06-27-2014 09:23 PM
