Unknown knocking sound
Old Jul 24, 2010 | 01:50 PM
physicsguy11's Avatar
physicsguy11
I have a weird sound coming from somewhere in the engine/tranny area, and I am trying to diagnose it. I happened to find this statement on another forum, and I was wondering if anyone here can confirm this from their experience:
"They are decent motors and can be built to make good power, but they have known oiling deficiencies...get in a truck or car with a 351M/400 in it that has some mileage (75k+ miles) on it, and more times than not, after the oil gets hot, you'll hear some bottom end (main bearing or connecting rod) knock. The oiling problems can be resolved, fairly easily, during a rebuild."
Also, how would a person solve this oiling problem during a rebuild?
Old Jul 24, 2010 | 02:43 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I would be more concerned with pin-pointing the cause of the "noise" rather than read about some issue that may or may not have anything to do with your problem.
It could be something as minor as loose torque convertor bolts, but you need to narrow it down.
Did the truck just recently start doing this or has it been a problem for as long as you have owned the truck?
We need more details...
Josh
Old Jul 24, 2010 | 02:45 PM
Blown 331's Avatar
Blown 331
Josh
I agree with this but also I've been around over 10 family owned 351m/400 engines that did exactly what the quote above is stating. Main and rod bearings and a high volume pump took care of more than half.
Old Jul 24, 2010 | 04:34 PM
physicsguy11
Ive owned it for several months now, and its likely that its had it for the entire time (every day is a new adventure in finding more stuff to be fixed), but I couldn't say for sure because I wasn't really paying attention... too many new noises for me. So.... at least a few months.
I only notice it driving uphill or accelerating with more than a light foot on the pedal. I don't hear it when Im cruising downhill, or on straight and level. It seems like it is a higher engine load issue.
BTW, Im driving a 79 F150 351m, 4wd, automatic
Last edited by physicsguy11; Jul 24, 2010 at 04:43 PM. Reason: forgot to answer a question!
Old Jul 24, 2010 | 07:46 PM
Shooter00's Avatar
Shooter00
This might seem elementary, but I tracked a knocking noise similar to what you're descibing to my PCV valve.
Old Jul 24, 2010 | 08:48 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
I would say check your timing and your fuel/ air mixture. Your mixture may be too lean, or your timing may be advanced too far. This will be painfully obvious during quick acceleration or under load, as you described.
It definitely sounds to me like it's pinging, not knocking. Knocking indicates a physical mechanical issue...pinging is a fuel/ ignition issue.
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
Celicadude
Sep 25, 2006 11:50 AM
PG Stroker
May 25, 2006 05:17 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
