Sponsored by: Real Truck
9400# gvwr pkg
Old Jul 23, 2010 | 10:01 PM
pkenn7's Avatar
pkenn7
9400# gvwr pkg
what is it exactly??
Old Jul 25, 2010 | 10:18 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It means you have a single cab, long bed F250 probably.
GVWR is a largely arbitrary number assigned by Ford to a cab/bed and badge combination. In 2007: A CC/LB F250 has a GVWR of 10,000#. A CC/LB F350 has a GVWR of 11,500#. The difference between the two trucks? A rear suspension spacer, and the GVWR number on the VIN sticker. Spring codes, rear aux springs, and the half dozen other very minor differences between 250 and 350 series trucks are all selected based on packages, and don't have an effect on the GVWR. It's very possible to build an F250 with higher spring codes that result in higher axle weight ratings than on a comparable F350, but the Gross weight rating never changes.
GVWR is a legal registration issue in a lot of states. You can buy an F250 with a GVWR of 10,000# and not have to have commercial insurance while not sacrificing frame strength, engine choice, etc, or you can buy a 99% identical F350 with a GVWR of 11,500# if you need to legally carry/haul more than 10,000#.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
