steering coluum issues?
Old Jul 23, 2010 | 06:56 PM
alconk's Avatar
alconk
My 79 F-100 steering coluum has rattled ever since I got it and is driving me nuts.. I have replaced all the guts except the lower bearing and that's because the sound is coming from the shifter area..(automatic) And if you slightly move the gear selector towards 2nd the rattle goes away?? And now what it's been doing the last couple days is when I turn the wheel I'm getting a rub/ squeal noise in the area of the steering wheel meets the coluum?? Any ideas??
Old Jul 24, 2010 | 12:48 AM
steponit's Avatar
steponit
Tilt or Non-Tilt ?
Old Jul 24, 2010 | 10:20 AM
alconk's Avatar
alconk
Originally Posted by steponit
Tilt or Non-Tilt ?
Non-tilt fixed coluum
Old Jul 24, 2010 | 10:06 PM
steponit's Avatar
steponit
Inspect the grommets in the linkage for being worn out/sloppy
Old Jul 24, 2010 | 10:27 PM
alconk's Avatar
alconk
Are they rubber grommets or plastic and where are they located? I didn't see any when I had the coluum apart..Unless it's in the engine compartment??
Old Jul 24, 2010 | 10:30 PM
steponit's Avatar
steponit
They are more like neoprene.
Also Have you adjusted the linkage by placing the transmission in park then indexing the NSS ( Neutral Start Switch) in neutral?
You have to do it in neutral ..not park
Rivercityman
Escape & Escape Hybrid
26
Dec 1, 2013 02:03 PM
berry1234
Apr 18, 2011 05:02 PM
jtexfisher
2004 - 2008 F150
Dec 20, 2006 06:28 PM
Motley
1997 - 2003 F150
Jan 22, 2004 10:44 PM
