Sponsored by: Real Truck
Brake Lights do not work
Old Jul 23, 2010 | 01:54 PM
wrigbret's Avatar
wrigbret
I have an 00 f450 4wd 6 speed. Brake lights do not work. Hazards, turn signals, and lights all work. Have checked the brake light on off switch. I have a chiltons for 250/350 and do not know if the wires are the same color code as the f450. The colors given in the chiltons are there but test differently. Any thoughts.
Old Jul 23, 2010 | 02:02 PM
dchamberlain's Avatar
dchamberlain
Have you checked fuses? If you don't have the owner's manual, you can get it here...
https://www.flmowner.com/servlet/Con...ionalEventPage
What did you do to check the brake pedal switch?
Old Jul 23, 2010 | 06:22 PM
99f350sd's Avatar
99f350sd
The sw attached to the brake pedal...Wires etc.. Maybe it got banged around.
Old Jul 26, 2010 | 02:50 PM
wrigbret's Avatar
wrigbret
Brake light switch was bad. $13 fix.
Thanks
Old Jul 26, 2010 | 04:56 PM
99f350sd's Avatar
99f350sd
No problem glad we could help..
Dick
emanualshift
31
Jul 10, 2019 02:01 PM
TRX450R
Jun 29, 2007 12:51 PM
65comet
Electrical Systems/Wiring
Feb 27, 2005 11:13 AM
SpeculatorNY
Jul 27, 2004 10:24 PM
navynuke04
Nov 5, 2002 01:31 PM
