1971 F100 wiring diagram needed
You probably can buy them at the store on this site. If you have a testlight or voltmeter, you should be able to figure it out without a diagram.
Put the testlight or voltmeter positive lead on one side of the brake switch. Put the negative lead on a good ground. You should read 12 volts. If not, go to the other side of the brake switch. You should read 12 volts. One side of this switch has got to have 12 volts on it, and that comes from the fuse box.
Now read the opposite side of the brake switch with the pedal pushed. You should have 12 volts with the pedal pushed, and no volts when you let up on the pedal.
If all that works, you then need to go to the steering column. Make note of the color wire that had on-off 12 volts on the brake switch. You will find this same wire going up the steering column. If you test it going into the turnsignal switch, you should get the same on-off 12volts when the pedal is pushed that you got before.
If you have the on-off 12 volts going into the turnsignal switch, and your rear turnsignals do work, then your turnsignal switch is bad.
The rear turnsignals use the same wiring and bulbs as the brake lights. So if they work, that means the wiring and the bulbs are good from the rear all the way to the turnsignal switch.
Using the CD from motorhaven.com I rewired the whole light system on my 1971 F-100 including under the dash and eliminated the column switch. The only thing I do not have is the self canceling cam. I put everything (stop, parking, turn signals) on its own 30 amp relay so my trailer stuff will not overload the headlamp relay.
The easiest way to track down problems is to unplug the harness under the hood, stick a test light clip into one of the four holes and figure out if you are actually getting power out of the cab side. If you are, then the easiest thing is to go buy a 4 wire trailer harness for $15 at Advance Auto Parts and run it all the way back to the rear lamps and splice in new bulb connectors.
If you plan on trailer towing, then for each wire (four) run an extra wire from the butt connector to a Hoppy converter and that to a 7 pin/4 pin connector from Northern Tools so you can use both 7 pin round and 4 pin flat connectors on trailers.
You can do the whole thing for under $80 including the connectors and adapters for trailers. Or $30 if you skip the trailering stuff and relays.
I am also interested in finding out how you did it--i have a 1973 F-100 2wd/360....I am currently having problems wiring turn signals and brake lights....i had a setup that worked for a while then quit....now the battery is being drained...got an open circuit(burning switches 2)....
any help would be appreciated
Jeff
Jeff
Amish65F100
05-05-2017 05:19 PM
Carmax
21
03-15-2017 01:13 PM
jasindude1
04-13-2016 05:06 PM
