Filler Pipe
Old Jul 23, 2010 | 11:22 AM
tonyurban's Avatar
tonyurban
Filler Pipe
Hi Folks... first post here.
I have a new-to-me 2000 Excursion (88k miles, V10, 4x4). While on a road trip a few days back, I stopped at a gas station to fill up. While filling, I noticed a slow drip coming off my rear springs underneath the driver rear. The slow drip became a fast leak and I noticed that most of it was coming from underneath the truck where the filler pipe meets the panel. Once I shut off the pump, the dripping stopped. It drives normally otherwise.
I stuck my hands up around the pipe and noticed that it's very corroded. I couldn't feel a hole or a crack in the filler or vent pipes but I'm sure it's probably there and I can't find it. But, the next time I filled up, it did the same thing. Fortunately, I can get the truck filled with gas (and make it home) but it leaves a stinky mess.
I think I need to replace the filler pipe. I can't find a specific part number and doing some searches makes me think that this is a dealer-only part. Does anyone have a part number so that I can shop it around? Anyone have a recommended parts dealer (board sponsor?)?
It looks pretty easy to replace so that shouldn't be too difficult.
And, hi to everyone. I love my Ex so far.
Tony
Old Jul 23, 2010 | 11:46 AM
katiesdad7's Avatar
katiesdad7
Sounds like a loose hose clamp to me.
Old Jul 23, 2010 | 01:06 PM
tonyurban's Avatar
tonyurban
From what I could tell, it looks like it's leaking from somewhere up high on the filler pipe. It did not look to be leaking at the hose clamps but I will double check them.
Old Jul 23, 2010 | 01:26 PM
fiveohpatrol's Avatar
fiveohpatrol
I had the same problem a while back. Mine had some pin holes in it but seemed to be salvageable, so I sanded down the effected area, gave it a couple coats of JB Weld, and a coat of paint for good measure. Seems to be holding so far.
Old Jul 24, 2010 | 09:55 AM
tonyurban's Avatar
tonyurban
The hose clamps were indeed toast. I touched both of them with a screwdriver and they both broke right off. I replaced them but I still need to go fill it up.
Old Jul 24, 2010 | 11:58 AM
jh818's Avatar
jh818
Interesting you didn't get a CEL (Check Engine Light), or on the Ex, there is a gas cap light. The fuel tank system draws a vacuum to detect any leaks. If there is a leak, the light comes on.
Old Jul 24, 2010 | 03:10 PM
BigPigDaddy's Avatar
BigPigDaddy
After you fill it up with gas you need to drive west and get out of the rust belt!
Old Aug 9, 2010 | 09:43 AM
tonyurban's Avatar
tonyurban
Just a followup...
I installed new hose clamps and they didnt fix the problem. Something is still leaking so I ordered a replacement filler pipe. The part # is YC3Z9034BA just for forum reference (thanks partsguyed).
Old Aug 9, 2010 | 01:20 PM
Stewart_H's Avatar
Stewart_H
Partsguyed.com is a supporting vendor and runs a Ford parts department, but based on your latest post, you already discovered Ed.
Stewart
Old Aug 9, 2010 | 06:02 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
pipe is on back order and still waiting for it to come in. ugh
Old Aug 9, 2010 | 06:12 PM
Maxium4x4's Avatar
Maxium4x4
This might be late but Welcome to FTE tonyurban Be patient on the back order.
Old Aug 9, 2010 | 06:54 PM
tonyurban's Avatar
tonyurban
Thanks for the welcome. No big deal on the back order... I can still get gas into the tank, so it's not slowing me down. I just want to increase the ratio of gas into the tank vs gas puddling on the ground.
Tony
Old Aug 10, 2010 | 01:01 PM
Parts Guy Wyatt
Former Vendor
pipe came in today. go figure.
tekprod
May 23, 2014 09:39 PM
ExploringNH
Jan 21, 2014 03:46 PM
reddhawk
Escape & Escape Hybrid
Jan 7, 2013 10:06 PM
Excursionicky
Nov 29, 2010 10:14 PM
woodzracer
Mar 26, 2009 08:02 PM
