Sponsored by: Real Truck
2004 6.0
Old Jul 23, 2010 | 02:17 AM
dh4ever77's Avatar
dh4ever77
i took the turbo off and cleaned it and took the egr up pipe and welded a plate in it to block the exhaust from getting in to the egr i put it all back together and it dosnt have the power it used to. and theres a blowing sound when i get about 2000 rpms all the clamps are tight and the y pipe is on straight and the exaust pipe is on there straight and tight. i can feel a little air blowing from the y pipe from the heat sheld were the rivit is any ideas what could be leaking or wrong ????
Old Jul 23, 2010 | 06:19 AM
scottzj's Avatar
scottzj
Hangin 10 bra
Well I did the delete kit to my 04 and removed all of that. However, I did notice that the blue rubber boot on the turbo had a crack in it. That caused my issue, but since you removed your turbo, you should have seen if this was the case. Your Y pipe could be worn out or rusted thru. You might need to remove it and see if this is the case. I do have mine that I didnt reinstall if you are needing that part.
Old Jul 24, 2010 | 11:05 AM
dh4ever77's Avatar
dh4ever77
i checked every thing and the boots and pipes all looked good when its sitting there running you can not hear it but when im driving with the windos up i can i was wondering if it was because the egr is blocked and the exhaust flow is diffrent now
Old Jul 24, 2010 | 08:31 PM
scottzj's Avatar
scottzj
Hangin 10 bra
Well I know my 04 has a major whistle now compared to what it did, after the EGR delete.
Old Jul 25, 2010 | 02:19 PM
dh4ever77's Avatar
dh4ever77
mine didnt change i think i have a cracked y pipe i will be taking it all apart today to see if i cant figure it out my dads buddies truck has a major whistle and he has the same truck year make and model
ithaca1230
Jan 2, 2013 09:27 AM
pnj442
Jun 22, 2012 11:32 PM
32MTXSHO
Nov 10, 2004 01:05 AM
BroncoMTR
1978 - 1996 Big Bronco
Jun 14, 2004 01:09 AM
