in tank mod problem
Old Jul 22, 2010 | 05:42 PM
edf250's Avatar
edf250
in tank mod problem
did the in tank mods now it runs poorlry under heavy acceleration like entering freeway.could it be air ? it feels like it is starving for fuel i used the itp kit .im thinking ill try to put a fuel pressure guage on it tommrow any ideas ?
Old Jul 22, 2010 | 05:54 PM
Robert6401's Avatar
Robert6401
How long since you did the mod? It takes a few miles to get out air that you intoduced into the system while doing the mod.
Old Jul 22, 2010 | 06:13 PM
orng1's Avatar
orng1
I can't imagine it would take to long to get the air out of the lines, how long did you drive it or let it idle EdF250?
Old Jul 22, 2010 | 06:17 PM
edf250's Avatar
edf250
i let the truck run about 30 min then drove on freeway about 15 min it strarted running ruff like it was trying to cut off ses ligt came on then went off after about 5min ill scan for codes tommrow
Old Jul 22, 2010 | 06:18 PM
edf250's Avatar
edf250
man i think i really need a fuel pressure guage
Old Jul 22, 2010 | 06:23 PM
ron's power stroke's Avatar
ron's power stroke
if you dont have a regulated return it could take 50 or so miles to work the air out...idle does not cut it..take it out and run it..
Old Jul 22, 2010 | 06:30 PM
puller45's Avatar
puller45
You may have pinched a line when you reinstalled the tank, mine ran fine immediatly after the mod. Did you install a pre-pump filter?
Old Jul 22, 2010 | 06:35 PM
edf250's Avatar
edf250
no pre pump filter till tommrow put in new main filter made no diffrence
Old Jul 22, 2010 | 07:35 PM
PaysonPSD's Avatar
PaysonPSD
If you didn't pinch or kink the fuel line you may have clogged up the pump's internal screen at the fuel pump inlet. The main purpose of a PRE-PUMP filter is so debris does not get to the pump and clog the screen or pump.
Old Jul 22, 2010 | 07:51 PM
tdpower's Avatar
tdpower
X2................................................ .............
dn29626's Avatar
dn29626
I added a G3 clear filter between the tank and pump. I let my truck idle about 20 minutes after the mod. I have had no problems.
I already have a pressure gauge. Take the time and install at least one.
My pump does not have a screen. I have checked it.
Old Jul 22, 2010 | 07:52 PM
edf250's Avatar
edf250
ill check the pump screen tommrow thanks
Old Jul 22, 2010 | 07:55 PM
edf250's Avatar
edf250
i have the itp filter kit im putting on tommrow im making a diffrent mount
Old Jul 22, 2010 | 08:52 PM
69Cobra's Avatar
69Cobra
Is the pre filter you guys are talking about the black plastic funnel looking thing on the bottom of the pick up tube? I'm wanting to do this mod this weekend so I'm taking notes.
Old Jul 22, 2010 | 08:59 PM
izzybird's Avatar
izzybird
No, they are talking about an aftermarket inline filter of some sort before the fuel pump
