Swapping out trans
Old Jul 22, 2010 | 02:31 PM
79FordBlake's Avatar
79FordBlake
Swapping out trans
The c4 in my 73 F100 302 is slipping fairly bad but I have a 74 F100 302 parts truck with a great shifting FMX in it.
I have done some measuring and both trannys seem to be the same length. Will the FMX bolt directly in place of the C4? Any help is welcome, thanks.
Old Jul 24, 2010 | 12:59 PM
79FordBlake
Anybody have any advice? I don't really want to pull either transmission until I know if its gonna work.
Im not sure if my driveshaft will work if I replace the c4 with the FMX.
The FMX is in a longwheel base truck, the C4 is in a shortwheel base so I cant change driveshats out.
Old Jul 24, 2010 | 06:41 PM
85e150's Avatar
85e150
OK, not a trans man and don't play one on TV, but reviewing your info:
--both from a 302, so it will bolt up.
--if you need to transfer the flex plate so it matches the new trans, your engines are both the same balance type, so no issue there. (see the sticky on top of the SBF forums about balance)
--both shift PRND21, correct? Check the levers on the trans, both down, or both up = no problems.
--cooler lines, check 'em.
--cross member, measure it.
--trans length, you have that covered
--output shaft spline--you'll know when you pull a DS.
--am I understanding you that you want to/seems like you should be able to--keep your existing DS?
--backup lights, neutral safety switch, check the wiring.
PROBABLY a direct bolt in, but if you cover those things before you pull the transmissions, you'll be prepared to run for some parts, do some mods or just swap it.
Sorry I can't be of more help. Now, since these last two posts bump the thread up, maybe someone else will see it and remember the time they swapped an FMX in for a C4, or vice-versa.
Old Jul 24, 2010 | 07:38 PM
79FordBlake
Both have same shift pattern. Trans cross member will have to be moved back(already another set of holes to put it in).
No wiring on either trans. The neutral safety switch is on the steering column on these years of truck.
Im worried about driveshaft length mostly. No problem switching out the flexplate if I have to.
Im not sure if both trans are actually the same length. Hard to hold the tape myself while under the truck and no help.
Thanks.
The FMX in the parts truck shifts very nice and firm. The c4 in my good truck is slipping bad goin to third. Would be great if this was a direct bolt in.
Old Jul 25, 2010 | 06:12 PM
85e150's Avatar
85e150
Sounds like you are pretty close here. The C4 is going to have to come out sooner than later, so maybe at that point you can do a better measure job and decide if you are headed towards a swap or a rebuild. Serving suggestion, ymmv.
79FordBlake
Jun 10, 2010 05:13 PM
Shane in WI
Feb 22, 2010 09:30 AM
1949f1
May 23, 2006 05:56 PM
briguyme
Apr 9, 2005 09:03 AM
cigarxtc
Jun 4, 2000 08:06 PM
