oil experts: Mobil Delvac 1 5W-40 vs Mobil 1 Turbo Diesel Truck for IDI application
on
oil experts: Mobil Delvac 1 5W-40 vs Mobil 1 Turbo Diesel Truck 5W-40 for IDI application
the oils:
Specifications and Approvals
Mobil Delvac 1 Meets or Exceeds the following industry and builder specifications:
5W-40
API CI-4 PLUS/CI-4/CH-4/CG-4/CF/SL/SJ X
ACEA E7/E5/E4/E3 X
Caterpillar ECF-1 X
Cummins CES 20072/20071 X
Detroit Diesel Power Guard Oil Specification X
Ford WSS-M2C171-D X
Global DHD-1 X
JASO DH-1 X
Typical Properties
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40ºC 102
cSt @ 100ºC 14.8
Viscosity Index, ASTM D 2270 151
Sulfated Ash, wt%, ASTM D 874 1.35
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, ºC, ASTM D 97 -45
Flash Point, ºC, ASTM D 92 226
Density @ 15ºC kg/l, ASTM D 4052 0.854
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Mobil 1 Turbo Diesel Truck Meets or Exceeds the following industry and builder specifications:
5W-40
API CJ-4, CI-4 PLUS/CI-4/CH-4/CG-4/ SM/SL/SJ X
ACEA E7/E5/ X
Caterpillar ECF-2,ECF-3 X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 100.4
cSt @ 100ºC 14.9
Viscosity Index, ASTM D 2270 155
Phosporous 0.12
HTHS Viscosity, mPa•s @ 150ºC ASTM D 4683 3.9
Sulfated Ash, wt%, ASTM D 874 1.0
Total Base #, mg KOH/g, ASTM D 2896 10.7
MRV @ -35 º c 25400
Flash Point, ºC, ASTM D 92 235
your thoughts for use in the IDI?
its time to go synthetic.but i don't want to overpay for something that's to no advantage or perhaps even less desirable for the old school, non emissions classic IDI.
the oils:
5W-40
ACEA E7/E5/E4/E3 X
Caterpillar ECF-1 X
Ford WSS-M2C171-D X
Global DHD-1 X
JASO DH-1 X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 102
cSt @ 100ºC 14.8
5W-40
ACEA E7/E5/ X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 100.4
cSt @ 100ºC 14.9
Phosporous 0.12
MRV @ -35 º c 25400
on
its odd,cus i could have sworn when i last researched delvac 1 that it listed CJ-4
CJ-4 Service Category Description
6. Do API CJ-4 oils protect older engines as well as API CI-4 or API CI-4 PLUS oils?
Yes, API CJ-4 oils are designed for use in new engines as well as the existing on-highway fleets. API CJ-4 oils are qualified utilizing several new engine tests that are more severe than those used for API CI-4 or API CI-4 PLUS oils thus defining a new category of oils with much more robust performance than previous categories. API CJ-4 oils are formulated for improved wear protection, deposit and oil consumption control, soot-related viscosity control, prevention of viscosity loss from shearing, used oil low-temperature pumpability, and protection from thermal and oxidative breakdown when compared to previous API performance categories. As always, users should seek guidance from their engine or vehicle manufacturer regarding specific service recommendations.
so that's a point for the turbo diesel.
EDIT!!!
oh i see how i frigged up.apparently there is a Mobil Delvac 1 ESP 5W-40
THATS the one i have been interested in.the "ESP" in the name is important.
here's that one:
compare this one against the turbo diesel please.my bad.
Mobil Delvac 1 ESP Meets or Exceedsthe following industry and builder specifications:
5W-40
API CJ-4/CI-4 PLUS/CI-4/CH-4/CG-4/SM/SL X
ACEA E7/E5 X
Caterpillar ECF-3 X
Cummins CES 20081 X
Detroit Diesel Power Guard Oil Specification 93K218, 93K214 X
Mack EO-O Premium Plus, EO-N Premium Plus 03 X
MAN M3277 X
MB-Approval 228.31, 228.3 X
Volvo VDS-4, VDS-3, VDS-2 X
Deutz DQC III-05 X
Twin Disc S364A X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 98
cSt @ 100ºC 14.7
Viscosity Index, ASTM D 2270 156
Total Base #, mg KOH/g, ASTM D 2896 10.1
Pour Point, ºC, ASTM D 97 -48
Flash Point, ºC, ASTM D 92 249
EDIT!!!
here's that one:
5W-40
ACEA E7/E5 X
Caterpillar ECF-3 X
Cummins CES 20081 X
MAN M3277 X
Deutz DQC III-05 X
Twin Disc S364A X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 98
cSt @ 100ºC 14.7
Either of those oils will be fine. Some engines do better with one oil over another as far as using oil and/or how well an analysis is.
For instance with a Cat engine, I have talked to mechanics that say with Shell Rotella, if the engine uses oil then change to Shell Rimula and the oil usage will stop.
Some Ford owners have no issues with Rotella while others will use oil with Rotella and no problem with another brand.
In the oil and lube forum there are some real knowledgeable guys and the general consensus is that just about any properly rated oil is fine and will do a good job. I've used Rotella T 15-40 since the late 70's, switched to Rotella synthetic when it came out. I use it in all my vehicles, gas and diesel, lawn mower, snow blower. My mower is almost 16 yrs old and still runs strong and uses no oil during the season. I changed the spark plug for the first time this year, starts on the first pull now instead of the second.
Well my auto shop teacher had a intresting point of view on oil hes theaory was the best oil is all of them that meet the requirements of your engine because each one has it own benifits some clean some protect som recondition seals and what not so he suggest use a diffrent brand each time. I just run rottela T because its what I can get cheap actualy right now I got the napa stuff because it was on sale when I went there.
They are all good oils, and have used them all. I prefer to use synthetic in everything because it just helps with heat and cold. Plus if you ever lose coolant for any reason or overheat, you will have protection in your engine that will be extremely protective. I learned that the hard way with a truck I blew the coolant out of and the temp gauge went at the same time (of all the friggen luck), but the synthetic allowed me to cool down and not have any problems after repairing the leak. No loss in oil pressure, no knocking, and opening it up for good measure to look around yielded no scoring, bad bearings, or warping. I was really thankful. Plus you will appreciate the help it gives during the cold months, if you have them. The engine will crank over easier and knock less with protection from moment one. That being said, some more "seasoned" engines will encounter seepage with the synthetic oil since it flows so well.
on
Not until it's broke in ... You must run dino until then else the rings won't seat.
Personally, I have done the testing, numbers and I don't see where Synthetic is worth it in a motor, Dirty oil is the real killer, leaving oil in as long as Synthetic lasts carries lots of filth through the motor.
And don't tell me the filter will filter it out, if you know anything about woven filters you'll know they won't, just look at your oil in the dark with a flashlight and you have all the proof you need!
I run dino in my motors and synthetic in gear boxes.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
on
I should also point out that I have disassembled a lot of motors and after a time you see what works and don't, Both Synthetic and Dino work equally well in protecting parts from wear as long as it's changed regularly, It very easy to see the motors that were taken care of and those that were not.
I'm not a Dino pusher or Synthetic, To me it's whatever you choose, just whatever you do choose, change the oil regularly!
Some of the cleanest (as in filth and wear) motors I've seen had their oil changed at 3500 miles or less regularly and religiously, it didn't matter if it was Dino or Synthetic.
There are some extreme cases on both sides that each have their own advantages.
For example, Synthetic absorbs heat better than Dino, But it's far worse at dissipating it, Dino absorbs and dissipates about equally, But Dino cannot beat Synthetics lubricity or it's ability to not break down under extreme heat as Dino will.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
ol-blu
10-09-2016 08:10 PM
