Confused on Mobil 1 Comparison
For a while I used M1 5W30, when the 0W30 Advanced Fuel Economy became available I started using it. Today out of curiosity I went to the website to find some more information and am confused about something I found.
Looking at the tech details I found this.
<table id="tblTabs" style="width: 454px; margin-left: 34px;" border="0" cellspacing="0" cellpadding="0"><tbody><tr id="trTabContent"><td valign="top" style='width: 10px; background-image: url("/USA-English/MotorOil/Images/Tabs/box_Left.png"); background-repeat: repeat-y; background-color: rgb(201, 201, 201);'></td><td class="midBorder" valign="top" style='width: 435px; background-image: url("/USA-English/MotorOil/Images/Tabs/boxNoFade_Upper.png"); background-repeat: repeat-x; background-color: rgb(199, 199, 199);'>
<table width="435" border="1" cellspacing="0" cellpadding="1"><tbody><tr xmlns=""><td align="" class="bodyText" valign=""> </td><td align="" class="bodyText" valign="">
</td></tr><tr xmlns=""><td align="" class="bodyText" valign=""> </td><td align="" class="bodyText" valign="">
</td></tr></tbody></table>
<table width="334"><tbody><tr xmlns=""><td align="" class="bodyText" valign="">SAE Grade</td><td align="" class="bodyText" valign="">5W-30</td></tr><tr xmlns=""><td align="" class="bodyText" valign="">Viscosity, cSt (ASTM D445)</td><td align="" class="bodyText" valign=""> </td></tr><tr xmlns=""><td align="" class="bodyText" valign=""> @ 100ºC</td><td align="" class="bodyText" valign="">11.0</td></tr><tr xmlns=""><td align="" class="bodyText" valign=""> @ 40ºC</td><td align="" class="bodyText" valign="">61.7</td></tr></tbody></table>
<table style="width: 350px;"><tbody><tr xmlns=""><td align="" class="bodyText" valign="">SAE Grade</td><td align="" class="bodyText" valign="">0W30</td></tr><tr xmlns=""><td align="" class="bodyText" valign="">Viscosity @ 100ºC, cSt (ASTM D445)</td><td align="" class="bodyText" valign="">10.9</td></tr><tr xmlns=""><td align="" class="bodyText" valign="">Viscosity, @ 40ºC, cSt (ASTM D445)</td><td align="" class="bodyText" valign="">62.9</td></tr></tbody></table>
Wouldn't this indicate that the 0W30 is "thicker" at 40C then the 5W30? How can this be?
I've read all the numbers on the mobil site, the poor point only tells so much, the 0W30 is -50 and 5W30 -42, I see very little info though that would indicate viscosity at 0C nor a way to find it.
Where did you find that W=0F? I've never read that standard nor do I think it's correct.
Pour point tells me that the 0W is way thinner at real winter temps because it will pour when the 5W is jelly.
Good luck,
George
As is my nature, I did do a search anyway. The W weights have to do with cranking viscosities on 2 different scales at -25C and -30C:
Understanding Multi-Viscosity Motor Oils
So +40C is completely irrelevant to viscosity determination and is one point on the scale. How much time does an engine spend with the oil at +40C? A minute or so while it's warming up?
George
George
I used the M1 0w-30 this past winter to try. The truck sits outside and it was a colder than normal winter. (OMG the polar vortex, cold air never came down from Canada before) I normally run a 5w-30 synthetic like M1, M1 Ext Perf, Penz Plat and etc. It got down to a click or 2 below zero a couple nights and the truck did fire up easier when it is cold with 0w-30. Startup oil pressure was also less with the 0w than the 5w on my oil pressure gauge. So it looks like there is some difference. I'll probably put some type of 0W-30 synth in again this winter.
Honestly it would be nice if they would show viscosity @ 0 C and -30 C.
I think that the most useful number to compare oils in colt temps is the "pour point" number; an oil that pours at a much lower temp below zero is gonna have to be thinner at 0C or -30C. Even though viscosity curves are not linear, an oil rated at 0W has to be thinner at these low temperatures than a 5W.
Ultimately, if you live in a truly cold climate, a block heater would be the way to go...or one of those heaters that splices into a radiator hose or something.
I've never had a cold weather starting issue in Michigan using Motorcraft 5W20 syn blend, and I've owned my '02 E150 (4.6) since new. I ran full syn 5W20 for a couple years (got 24 quarts of Quaker State Torquepower 5W20 for 99 cents a quart) and really did not note a difference.
I've spent some time on the BITOG pages and could become a motor oil collector/hobbyist, but ultimately the payoff really isn't worth the time and worry. My van will rust away before the engine ever has an oil related issue. I like 5W20 Motorcraft syn blend.
George
Based on your original numbers, the 0W30 would be expected to flow better at startup because of the lower pour point but be just about the same as 5W30 at 100C. The only difference might be shearing over time--would the 100C viscosity be the same after 5000 or 7500 miles? If your oil consumption is not any greater with the 0W, I'd say it would be fine--but doing used oil analysis would tell you more.
There are so many mod motors that have gone 250k and 500k miles using plain old Motorcraft 5W30 and 5W20 that I think long term wear due to cold startups is not that big an issue. What engine do you have in your truck, how many miles on it, and what is your oil consumption like?
I've had some personal experiences with Mobil 1 in a Subaru that I am a bit leery about it shearing down over time (my Subaru and others seem to consume more Mobil 1 than Synpower)...too much to get into right now, but I'm more of a Valvoline Synpower or Pennzoil Platinum/Ultra fan in terms of full synthetics in my Subaru. But I've only used 5W30 in the Sube for its lifetime.
George
George
VI breakdown shouldn't be the issue it is with dino oil.
My bad but this isn't for a Ford truck, it's a Nissan V6 with 140K. Owned it since 11K and it consumes no noticeable oil. I'm changing it at 10K intervals, and not going to bother with analysis.
My trucks are all diesels and 460s that get Rotella T6 5W40. I'd consider a 0W40 or the Mobil 1 diesel 5W40s but I bought a bunch of T6 on sale and have enough for some time.
I agree...even though I said I wasn't gonna research this, it looks as though the +40C viscosity rating is based either on typical oil storage temperatures (as in a huge outside tank in the sun) OR, another plausible explanation that I ran across is that this is the operating temperature of factory floor machines that don't involve internal combustion engines. The 100C is a useful gas engine operating temperature rating.
I'm not really concerned about very low temp starting at all, only startup wear. It doesn't get cold enough here to worry about, mid 20sF for a few days a year as about it. I just figured with a quality brand like M1 if 5W30 was good then 0W30 for the same money would be better.
Now I can see if you get a UOA after 10k miles with say M1 5w-30 I can see wanting to stick with 5w-30 M1 next time around. For me I don't put all kinds of money into UOA like some guys do. For what UOA with TBN costs I can change the oil for a few bucks more.
For startup wear prevention IMO the oil filter (anti drainback valve) is a big part. I avoid certain filter brands, for my Fords it is Motorcraft filters or a Purolater Pure One in a pinch.
For your conditions I would just run the 5w-30, as it is more common. Myself I am not really brand specific, I just use a good quality major brand oil. For instance Wally world had M1 on sale for a tad under $23 5 quart bottle which is cheaper than Pennzoil Plat, Valv Synpower and etc that was next to it. Sometimes Pennzoil Ultra is on sale so I buy that.
My best deal on full syn was 24 quarts of 5W20 Quaker State torquepower on an Advance Auto closeout for 99 cents a quart (4 changes for my van for $10 each including a Motorcraft 820S). Hard one to turn down... And I'm with you on filters--Motorcrafts on my E150 or Purolators (which make Motorcraft), usually Pure Ones, which I get in bundled deals with oil on sale.
My van is back on Motorcraft syn blend and it is great oil.
George
