HEY ALL. I have a 99 Ranger 3.0 and need to remove the A/C condensor. It has a good size leak and I would like to replace it asap due to the fact this summer has been like hell so far.My question is this: If I raise the truck can I drop the condensor down for removal or do I have to lean the radiator back and remove it from the top. Any answers are appreciated!
The Ford Manual says you should remove it from the top:
1999 Ranger Workshop Manual - SECTION 412-03: Air Conditioning
Condenser Core - Removal
1. On the 4.0L engine remove the air cleaner outlet tube and the engine air cleaner; refer to Section 303-12 .
2. Recover the refrigerant; refer to Section 412-00 .
3. Disconnect the condenser to evaporator tube (19835) from the A/C condenser core.
4. Disconnect the A/C manifold and tube (19D734) from the A/C condenser core.
5. Remove the radiator mounting screws and tilt the radiator (8005) back.
6. Remove the push pins and remove the top seal.
7. Remove the condenser core mounting screws and remove the A/C condenser core.
Installation
1. Follow the removal procedure in reverse order.
2. Lubricate the O-ring seal with Motorcraft YN-12c refrigerant oil or equivalent meeting Ford specification WSH-M1C231-B.
3. Lubricate the replacement A/C evaporator core (19860) with the correct amount of Motorcraft YN-12c refrigerant oil or equivalent meeting Ford specification WSH-M1C231-B; refer to Section 412-00 .
