Cruise control problem
Jul 21, 2010 | 08:49 PM
I was driving home from work tonight and had cruise set as normal and all of a sudden it just kicked out and I couldn't get it to turn back on. Checked every fuse in dash panel and power distribution box under the hood and all check ok. Air lines and plug to the cruise controller look good as well. Help anyone! I need my cruise bad
Jul 21, 2010 | 08:55 PM
Did you check the vac connections under the dash at the pedals( brake and clutch)? I had that problem before and that was the culprit.
Jul 21, 2010 | 08:58 PM
No ken not yet, will run out and do that after dinner. Were are they exactly ?
Jul 21, 2010 | 09:49 PM
Wonder if the cable snapped. I've seen it happen on the pre 1992 version, but am not sure if the cable is accessible on your verison.
Jul 22, 2010 | 06:59 PM
They are up underneath near the brakelight switch. They are the only vac operated stuff under there.
Jul 22, 2010 | 08:20 PM
This is a 92 David, cable from what I could see looks good. I am off work tomorrow so I can crawl under the dash and look for those lines you speak of Ken. Sucks right now driving the 30 miles to work without my cruise!
Jul 22, 2010 | 09:45 PM
Jul 22, 2010 | 10:05 PM
lol @ greywynd
If I lived in town I would never use it but for my drive to work it is nice to have.
Jul 22, 2010 | 10:15 PM
IIRC in rush hour traffic cruise won't work anyway.......
gotta be doing over 30MPH for it to kick in........
Jul 22, 2010 | 10:19 PM
Quote:
Originally Posted by
PLC7.3
Rush hour were I live is a combine driving 10mph down the highway
Jul 23, 2010 | 08:00 AM
greywynd
I like a 2x4 wedged btwn the seat and the skinny pedal personally lol
Jul 23, 2010 | 09:19 AM
Jul 23, 2010 | 10:28 AM
if i am not mistaken, the 92 uses a "clockspring" in the column. one of the classic signs of a bad clockspring is cruise control, or horn failure.
Jul 23, 2010 | 06:23 PM
Cruise, what is cruise? I run 37 miles one way and about 28 of that it freeway. I never use cruise I don't even have it lol.
Jul 23, 2010 | 07:12 PM
WarOzz
Then you don't need cruise, but a manual fast-idle switch instead - works wonders in creeper traffic
Orlie
Feb 27, 2023 09:32 AM
mksnipe
Dec 15, 2015 08:22 AM
hawesra
Jul 21, 2014 08:01 PM
ErrorS
1978 - 1996 Big Bronco
Dec 5, 2011 08:22 PM
Jaaaaaaackman
Sep 21, 2007 09:33 PM
02 ,
1990 ,
73 ,
97 ,
control ,
cruise ,
f150 ,
f250 ,
ford ,
idi ,
problem ,
problems ,
truck ,
v6 ,
working
