P1151
Old Jul 21, 2010 | 05:30 PM
charlie268's Avatar
charlie268
P1151
Just got a cel with this code and had it scanned, looks like a lot of different things could cause this. History, replaced tps, idle air, cleaned Mas air flow ( a while back). Does anyone know what the usual cause or most prevelant is? No other codes with this!!
Old Jul 21, 2010 | 06:35 PM
powersmoked's Avatar
powersmoked
we need more info about your truck..........you have my permission to use my profile/signature as a temp let
Old Jul 21, 2010 | 07:56 PM
g_k50's Avatar
g_k50
DPFE, replace
Old Jul 21, 2010 | 08:24 PM
powersmoked
Originally Posted by g_k50
DPFE, replace
stevie wonder.........I would DX first then replace......have we talked about fuel pressure..........
Old Jul 22, 2010 | 06:46 AM
pawpaw's Avatar
pawpaw
P1151 cause could be a number of things. Read through & check this list of things & let us know what you find.
WikiAnswers - What is code p1151 on a ford expedition
Old Jul 22, 2010 | 07:53 AM
powersmoked
building on what pawpaw said. if it was my truck i would change the fuel filter and add some techron to the tank, possibly start cleaning out the egr, check fuel pressure, check connection on the o2 sensor...etc.....
Old Jul 23, 2010 | 11:39 AM
charlie268's Avatar
charlie268
Sorry I didnt put all the info. My truck is a 2000 extend cab, 4wd, auto, 4.0 motor. I changed the fuel filter last fall. It seams like this ll51 code is a catch all code. Thought it would be a little more exact with having a pcm with codes. Had the cel reset and 2 days later it came on again. Runs fine, no misses, but mileage dropped probably 2 to 3 miles per gallon. I drive it 110 round trip every day to work, so I check mileage almost every day!!!
Nitesaber
13
May 25, 2022 07:38 PM
BRNZY
2004 - 2008 F150
Jul 4, 2010 02:04 PM
jeremy53402
Jun 29, 2008 05:46 AM
surferbum
May 28, 2007 01:54 PM
12013134
1997 - 2003 F150
Jun 26, 2003 08:56 AM
