You can easily get ARP head studs for the 6.9L engines. Head studs for the 7.3's are a little more of a process. 7.3 rocker arms are a good upgrade for the 6.9's. You can intercool it but you'll be on your own for the plumbing setup to do it.
intercooler is best if you can find it from a JY. I think oreo got his that way. They are a dime and a half new so fyi. If it has a banks, there may be head studs already, look before you buy! Biggest weakspot is going to be cavitation, how was it kept, SCA's in the coolant? Give a history, itll help everyone diagnose it better,
To tell if it has studs look at the head bolts along the bottom of the heads. If they have nuts on them instead of bolt heads it has studs in it, if not then its still standard head bolts.
