Bronco II Ford Bronco II
86 B2 4x4 A4LD Code 89 Help!
Old Jul 21, 2010 | 01:10 PM
the slider's Avatar
the slider
I just had my tranny rebuilt and driving it it 2 days later it started shifting funny and dying when i would turn a corner or shifting. I ran codes and at Key on engine off i got a code 89. Is there a fix for this? or am i looking at another rebuild? it was rebuilt about 3-4 years ago. i know the a4ld's are junk but i dont wanna put a standard tranny in it..
Thanks!
Chaz.
Old Jul 21, 2010 | 02:32 PM
mrshorty's Avatar
mrshorty
KOEO 89 points to an electric fault in the torque converter lockup clutch solenoid circuit. I'm not sure that I would expect this code to be related to it "shifting funny" and really have a hard time picturing how this contributes to it "dying when you would turn a corner."
The TCC solenoid circuit is a pretty basic DC circuit. It shouldn't be too difficult to track down the problem that is causing the KOEO 89 (who knows, maybe it never got plugged back in when the rebuild tranny was installed). You can then see if that resolves the issue or go on to something else.
Old Jul 21, 2010 | 02:57 PM
the slider's Avatar
the slider
Where abouts on the tranny is the elkectrical plug? that was i can see if it got unplugged.
Thansk!
Chaz,.
Old Jul 21, 2010 | 11:43 PM
mrshorty's Avatar
mrshorty
I can't describe exactly where it's at, but the TCC solenoid plug will have two wires in it, and plugs into the driver's side of the transmission.
Old Jul 22, 2010 | 09:29 AM
the slider's Avatar
the slider
Ok, Thanks!!! Next time Im out where i have it parked illl go look!!!!
Thanks Again!
Chaz.
Old Sep 28, 2010 | 04:41 PM
the slider's Avatar
the slider
Sure enough!!!! It WAS unplugged!!!! I havent had a chance to test drive it.. but what happens when it get unplugged and driven? since none of my symptoms had nothing to do with it??
Thanks Again!!!!
Chaz
89_Brnko2!!
Bronco II
Dec 10, 2008 02:26 AM
guitarman 39
Aug 12, 2004 04:09 AM
dlink
Bronco II
Jan 3, 2004 03:32 PM
benefital
May 8, 2003 01:33 PM
rokinrik
Bronco II
Apr 21, 2001 02:21 PM
