i need help finding either a holley 2300 2bbl carb or a hollley 4bbl intake for my 1959 f350 its currently has a 292 y block in it and i need 1 of these parts to get it running again<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Try your local parts store.
They (Holley) make a 350cfm 2300 that has a manual choke still. You may have to adjust the jets and powervalve but otherwise it will be a bolt on.
A 52 jeting and a 7.5PV should do you well.
Reason: cat in pants
