59 ford ignition switch
Old Mar 18, 2011 | 08:02 PM
ptra2417's Avatar
ptra2417
how do you get the lock cylinder out of the ignition switch? i have the key
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Old Mar 18, 2011 | 09:37 PM
Mike's Fine 50's Avatar
Mike's Fine 50
Insert the key and turn it to the on position and depress the small button on the bottom side of the switch and pull on the key to remove the key assembly. When installing the assembly make sure that the key is in the on position and the button is pushed in. Then insert the key assembly into the switch and line the button up into the slot and turn the key to the off position. Hope this helps. Mike
jeffleard
1997 - 2003 F150
Dec 7, 2013 05:21 AM
ptra2417
May 28, 2011 12:28 PM
ptra2417
Aug 13, 2010 10:00 PM
ptra2417
Jul 20, 2010 11:37 PM
eldorado
2009 - 2014 F150
Aug 17, 2009 11:25 AM
