Died while driving down the road...help !!
Old Jul 21, 2010 | 03:45 PM
novice psd's Avatar
novice psd
Originally Posted by Thewiller
Thanks for all the help. I went to the dealer and they gave me a new "grey" CPS under the recall for N/C so I really could not be fussy. Came home, put it in and started up and seams to run good around the block. What could be wrong with the grey sensor ? Will it not last as long ? Any suggestions for parts to carry as I use the truck for long RV vacations. I would have soiled my wears if this would have stopped working on the Chesepake Bay bridge and tunnel last week :}
Glad you found your trouble. Mine did the same thing, replaced cps, no help. Ended up a blown fuse from a wire grounded to the shock mount on the driver side thus blowing fuses which also ran the computer. This also gave about the same symptoms as a bad cps.
Old Jul 22, 2010 | 08:10 AM
westpsd's Avatar
westpsd
My truck acutally runs better on the new grey CPS. I have both, the grey and the black and keep the black one as a spare in the glovebox.
Glad you got it going!
Jim
Old Jul 22, 2010 | 11:19 AM
rwilkietx's Avatar
rwilkietx
CPS
International has the cps cheaper (at least in Tx). I would bet thats what it is. See if your tach moves when you turn it over.
Old Aug 31, 2018 | 04:26 PM
Tomulve's Avatar
Tomulve
I have same problem but with ford f250 with the 6.0
Is the cps the problem with mine? I've also been told the icp sensor could be my problem?
Old Aug 31, 2018 | 05:44 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You can unplug the ICP sensor and run the truck without out. That will tell you if your ICP sensor is the issue.
If not, perhaps start another thread with a different subject line. The one above grabs a lot of attention from the FTE as we don't want anyone stranded.
Old Aug 31, 2018 | 05:49 PM
Tomulve's Avatar
Tomulve
Originally Posted by westpsd
Sorry, forgot to answer your question....replace it. As mentioned before, make sure your "Wait to start" light comes on when you turn the key to on. If it doesn't, then it is a blown fuse. Happened to me a couple of months ago.
Jim
my 04 f250 is doing the same thing.. We were stuck on the side of the road watching you tube videos on it trying to get it started.. I unplugged the icp sensor and we got it running again eventually. It still sputters alot, its lost power and dies on me many times but usually starts back up easily. Could this be the same issue?
Old Sep 5, 2018 | 09:20 AM
danskool's Avatar
danskool
Go Bills !
All Fixed up ?
had this happen to a friends truck, had to go rescue. Fuel pump died. It would build 30psi veeeeeryyy slowly so the truck would start and run. Hit "go" peddle and pressure would drop to zip.
Old Sep 5, 2018 | 09:48 AM
timmyboy76's Avatar
timmyboy76
You'd have a better avenue if you listed in the 6.oh forum
bluegoose95401
Sep 21, 2016 08:44 AM
slus
Jun 15, 2015 10:59 PM
DBS1
Apr 28, 2014 08:31 PM
mrjc
6.7L Power Stroke Diesel
Sep 25, 2012 10:59 PM
notawordok
Apr 9, 2012 04:05 PM
