Oreo got me thinking
Old Jul 19, 2010 | 08:11 PM
kenpobuck's Avatar
kenpobuck
Ok I have been mulling this over for a long time but don't know enough to figure it out. We all know that the design of our exhaust manifolds sucks at least the driverside. I want to build custom manifolds and plum them into a turbo sitting right above the bellhousing. With the lift I did I have plenty of room there. I think it should still be able to gravity drain oil back to the pan from there. What dia. pipe should I use for the log on the manifold to get the best flow and to help spool the turbo? Also would angling runners off the heads be better or running them straight out ( I figure angle would be better)? Would these shorter runs to the turbo help spool it faster as well? Can you clock the housings on the turbo to change the inlet/outlet? Finding just a used turbo cheap seems to be easier than the whole system and fabbing something up pretty simple. Any info would be great. Also what is the max boost I would want to run? I did do the arp studs when I put the new heads on but want to keep it under gasket blowing pressure.
Old Jul 19, 2010 | 09:35 PM
oreocreaming's Avatar
oreocreaming
ok, are you trying to run 1 tube per cylinder and run them into a collector or you want 1 tube the whole span and just cut holes into it and run a stubby piece to the block?
Old Jul 19, 2010 | 09:36 PM
powerstroker100's Avatar
powerstroker100
this sounds awesome, Im not sure but wouldnt smaller diameter pipe mean that the air flows much faster through it because its buillding a bit of pressure? and will the turbo heat up really bad being crammed in there?
Old Jul 19, 2010 | 09:37 PM
powerstroker100
nevermind I forgot about the body lift
Old Jul 19, 2010 | 09:52 PM
George D.'s Avatar
George D.
You wana use as samll of tubing as you can to keep the volocity up and make it as short as possible so the exaust has les time to cool befor the turbo. The intake side can be reclocked on almost all turbos as for the exaust some you can some you can't, If you find a turbo where the compressor and turbine housings are held on with v clamps then you can re clock them to any position you want where as if they bolt up you can only put them where the bolts line up. I think the ideal set up would be equal length headers as 1short as posible into 1" collectors then run 1" pipe from each header to the turbo and header wrap everything
Old Jul 19, 2010 | 10:08 PM
oreocreaming
imo 1" is too small. That engine will be struggling to push that exhaust out. I'd say 1 1/2" - 2". Just measure what your crossover pipe is and go that rout. Remember, volume is as important as pressure, if not more. 400 psi does you no good when it's pushed through a straw
Old Jul 20, 2010 | 12:08 AM
Marianna2003's Avatar
Marianna2003
Why reinvent the wheel, Stans-Headers has headers available. Pricey, but available.
Headers for Ford, Mustang, Pinto, Bronco, Cougar, Ranger, exhaust parts for home built do it yourself automotive headers.
Old Jul 20, 2010 | 12:26 AM
George D.'s Avatar
George D.
Thouse headers IIRC are for N/A motors and wouldn't be optimum for turbod aplication.
Oreo The more I think about it 1" is probly a bit small But the cross over doesn't need to be as big as it is in my opinion.
Old Jul 20, 2010 | 12:42 AM
oreocreaming
each exhaust port from the head to the manifold is 1 1/2" so i would keep that size pipe. if i were you. port matching the heads would be nice too
Old Jul 20, 2010 | 05:05 PM
kenpobuck's Avatar
kenpobuck
I want to run stubs into a common tube sorta like we have now. I have access to some 2 1/2 od 3/8 wall dom tubing (1 1/2" id) at work. Iirc our exhaust ports are rectanguler. So I would need some rec. tubing as well. As for the connections at the turbo could I use some of the braided flex tube? I want to be able to have some give in this area for mounting. Also would it help if the stubs were curved or angled in the direction I want the flow to go or would it be overkill?
Old Jul 20, 2010 | 05:15 PM
swooshcmk's Avatar
swooshcmk
If you can find some solid steel bar scrap the same size as the port (or close to it) you can grind it down to make yourself a "Round to square press die" Then cut yourself a section of round tube and press/hammer the die into the tube to force the one end square to match the port.
Or you may be able to just smoosh the round pipe with a vice and hammer the top/bottom flatter... maybe some coaxing with a torch to help it along.
Best ideal would be each cylinder equal length of pipe into a venturi collector. If the venturi collectors minor ID is = to the area of a port it will help scavenge the exhaust manifold. However that's a lot of work so really don't see it on anything but race cars. Burns stainless is a big supplier of the SS collectors for the race guys
Old Jul 20, 2010 | 06:23 PM
oreocreaming
2 1/2" od would be a bit bigger then 1 1/2"id if its 3/8 wall. should be like 1 3/4" id. but i think that would be alright. not the ideal for free flowing but it would keep the psi up in the exhaust. id of the factory manifold has to be easily 2-2 1/4" id. our exhaust ports are rounded, you can use round tube just fine. and having it angled back would help with the flow.
Old Jul 20, 2010 | 06:25 PM
oreocreaming
that is WAY more work then it needs to be. just get yourself an anvil with the spike end. knock the pipe into the spike a few times and it will square it right up for ya.
Old Jul 20, 2010 | 06:29 PM
kenpobuck's Avatar
kenpobuck
Ok they are round ports. That makes things alot easier lol. I can use weld fitting elbows for the stubs. 3/8" cold roll for the flanges and 3/4" cold roll for the flange that mounts to the turbo. I would like to use a turbo for on of these IDIs but if that is not accessable what other cars/trucks could I search thru to find a substitute? The pressure hat should be pretty easy to do. As for the air cleaner I was thinking about one of the sealed plastic units used in most vehichles these days. That would give easey access to filters as well even K&N if I want. What is a safe psi level with the studs, maybe 15 or so?
Old Jul 20, 2010 | 06:32 PM
kenpobuck's Avatar
kenpobuck
Ya I need to check that dom again. I was going buy the inventory tag that is still on it. Geuss some one can't read a tape lol. Best part there is 20' of it and it has been counted 3 yrs in a row, never had any cut off of it.
