Oreo got me thinking
Old Jul 20, 2010 | 07:24 PM
Marianna2003's Avatar
Marianna2003
Originally Posted by George D.
Thouse headers IIRC are for N/A motors and wouldn't be optimum for turbod aplication.
Oreo The more I think about it 1" is probly a bit small But the cross over doesn't need to be as big as it is in my opinion.
Air flow is air flow. Wether is hot or cold it still conforms to the same laws. If you're talking about putting a Turbo behind the engine, above the transmission, why not take avantage of the best air flow you can?
The only thing I can think would be a concern would be the heat loss between the engine and turbo. Dave used exhaust wrap to conserve the heat on his engine. I can see where it would be highly beneficial.
Old Jul 20, 2010 | 08:45 PM
kenpobuck's Avatar
kenpobuck
It would be right above the bellhousing where it bolts to the engine. The tubing from the manifolds to the turbo would only be about 16 inches. I did plan to wrap this system sorta like Dave S. did his. I hope that this short distance would also make it spool faster and the location would still allow full access to the entire engine.
Old Jul 20, 2010 | 10:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think I would plan on 1.75" or 2" ID pipe for the log.
Angled ports from tyhe cylinder to the log..
Angled outlets that aim the exhaust at the turbo at the back of the engine.
If you set the turbo above the intake manifold, run the oil drain into the CDR vent tube location since the CDR has to be removed from the intake manifold port.
You are basically building a modified Hypermax turbo up pipe setup.
Anvil, hammer and torch, round pipe becomes any shape you need it.
Old Jul 21, 2010 | 06:59 AM
mistakenID's Avatar
mistakenID
I finally found the pic of an after market exhaust to turbo for the IDI. I also had a website that sold the part but can't find that. It's a bit pricey at around $480 if I remember right.
Pic looks like a powerstroke but I am sure I read it also fit an IDI.
Old Jul 21, 2010 | 07:20 AM
patrickke's Avatar
patrickke
id do something like the 6637 kit for the intake, k&N have some adverse side effects supposedly and can dust the turbo... Btw are you gonna bring the beast to RRE?
Old Jul 21, 2010 | 09:25 AM
wreckinball's Avatar
wreckinball
what schedule or thickness would be best for custom headers? i am going to get out my crayon to see if this idea would work that i have cooking in my brain thing. ill post the pic in one sec in an edit. Would something like this even help or allow a N/A to breathe better? Any diff at all?
Old Jul 21, 2010 | 10:59 AM
oreocreaming's Avatar
oreocreaming
that exhaust will not fit the idi the way it is. totally different outputs off the manifold.
Old Jul 21, 2010 | 05:23 PM
kenpobuck's Avatar
kenpobuck
Hey patrick! What is the rre? I think putting up as high as I can will let me use that for a drain. I will have to see what different sizes of tubeing we have at work. If none big enough I will order some. I figure i can use short radius 45* weld fittings off the head for 6 of them and a long radius 90 at #'s 1&5. Any one got any thoughts on what other vehichles I might look into for a used turbo for this app. Maybe even a used psd since i an makeing everything custom.
Old Jul 21, 2010 | 06:08 PM
George D.'s Avatar
George D.
FYI it's 1 and 2 they don't count them front to back on these engines.
Marianna2003
That's they make plasma cutters and TIG welders!
Old Jul 21, 2010 | 06:16 PM
George D.'s Avatar
George D.
That picture is of it on a powerstroke the dead give avay is the plugs at the end of the heads for the oil rail the one for the idi is difrent.
Old Jul 21, 2010 | 06:58 PM
oreocreaming
you cant tig cast. and its not worth trying to mod the up pipes. just build from scratch for 2/3 the price and 1/3 the headache.
Old Jul 21, 2010 | 07:08 PM
  #28
kenpobuck's Avatar
kenpobuck
Ya Geogre my mistake. I did know that but I got it in my head now for a gasser cause of my stepson's truck. I Tried to wire it using the diesel cylinder numbering lol. Took me three days to figure out why it wasn't running yet lol. Oreo, you can tig cast it is just a real pain in the @ss to do. I have never did it successfully my self but one of the guys at work does it on ocassion for us. He also does bronze, brass, copper, and cast aluminium. The cast iron he has done has been cast iron bells ( those things sound like cow bells) and on some of the old A-stands for bells when customers want to reuse old junk.
Old Jul 21, 2010 | 08:52 PM
  #29
George D.'s Avatar
George D.
Yeah we had a 302 in auto shop we couldn't get running untill we figured out ford numberd them front to back.
Old Jul 21, 2010 | 09:07 PM
  #30
patrickke's Avatar
patrickke
RRE 2010
Originally Posted by kenpobuck
Hey patrick! What is the rre? .
RRE is Riff Raff East its next weekend its like a huge diesel get together that is going to be near Knoxville pulls and other stuff check it out on the 7.3L section its being put on by Clay at Riff Raff among other people...
You should come down man its gonna be fun, plus you will get to see the 6.0l since its reinvention
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
