diesel swap help
Old Jul 26, 2010 | 07:32 AM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
Here You go
https://www.ford-trucks.com/forums/9...-96-frame.html
Old Jul 27, 2010 | 02:21 PM
02X72's Avatar
02X72
So I picked up the '88 donor and am probably gonna move my body onto that. Its an F350 frame so it so is much stronger, and the 7.3 is at home there. I figure the amount of work it will take to move my body to that frame is comparable to moving that motor and tranny to the f150's frame and beefing it up. Only issue is that I'm going to need to get a new shortbed, as the longbed I have now wont work( different wheelbases). I'll start a new thread on it in the '77 forum when I get going
Old Jul 27, 2010 | 09:03 PM
1967 Turbo 6.9
Well I'll be a smart *** and say You can make that frame any length You need.
But if a short bed is what You want that's doable to.
Keep Us up to date as You go please!
Old Jul 27, 2010 | 09:45 PM
02X72's Avatar
02X72
I could extend the frame on the rear, but that wouldnt do me any good. If possible I'd love to keep the longbed, but I dont think I can. To keep it I would have to move the cab forward ~20", which obviously cant be done since the motor gets in the way. Unless I'm missing something?
Old Jul 28, 2010 | 06:24 AM
1967 Turbo 6.9
You could lengthen the wheel base by adding to the middle.
This needs to be done by a Welder that know how not just someone that can weld.
Old Jul 28, 2010 | 09:21 PM
02X72's Avatar
02X72
Could I use a chunk out of the '77 frame, mainly asking if it would be string enough. Of course I guess i could just use thick steel plate to build the extension. I'm not familiar with this, so any idea what it wold cost to get that done or where I could/should take it to extend it?
Old Jul 29, 2010 | 12:14 PM
1967 Turbo 6.9
No the 77 frame is not as heavy.
If I were doing it There should be a length of straight frame just ahead of the rear axle spring perches.
I’d go cut what I needed out of a salvaged truck and add that to My frame.
One thing I have learned You don’t want to tell a Welder how to do things.
Best to ask Him how He wants to do it then decide if You’re going to hire Him.
Old Jul 29, 2010 | 02:44 PM
02X72's Avatar
02X72
I know a guy with a spare f450 frame that I can use. He said its a double frame, Ive never heard of that but theres alot I havent heard of. Looks like I'm going to be doing that in the next few weeks
Henryj1010
16
Mar 19, 2014 08:53 PM
Minime2010
26
Mar 6, 2014 10:46 PM
trumsey07
Mar 19, 2013 05:01 PM
02X72
27
Jul 23, 2010 08:53 AM
