New Guy Needs some help please!?
Old Jul 18, 2010 | 07:34 PM
mcmullinauctions's Avatar
mcmullinauctions
Hi,
I just bought an early model 2003 F350 with a blown 6.0 motor. I also have found a good running wrecked late built 2004 Ford F250. I keep getting conflicting opionions. Can I put the 2004 6.0 in my early 2003? If so what will I have to change around to make it work. I have everything from the 2004 if I get it so I should be able to do this right? Help! Thanks in advance!
Old Jul 18, 2010 | 07:59 PM
bismic's Avatar
bismic
Welcome to FTE.
I read about it being done. One of the issues encountered was with the electrical system (wiring harnesses IIRC). Can't recall if there was anything else.
At least this will be a quick "bump" for you.
Old Jul 18, 2010 | 09:48 PM
rickatic's Avatar
rickatic
It has been done. Look for posts by Slavik and Matty. Matty helped Slavik out quite a bit with info and advice. Time frame was last February or so. I put an 06 in my 04
Regards
Old Jul 18, 2010 | 09:53 PM
bismic's Avatar
bismic
Regards
Great post, good memory Rick - reps will have to wait though.
Old Jul 18, 2010 | 11:12 PM
rickatic's Avatar
rickatic
I am not sure it was as much good memory as it was that I was putting my 06 engine into my 04 truck at the same time. Matty helped both of us
Old Jul 19, 2010 | 07:15 PM
cheezit's Avatar
cheezit
remember this " make one look like the other it will work."
Old Jul 19, 2010 | 07:42 PM
npccpartsman's Avatar
npccpartsman
That should be a fairly easy swap--almost plug and play, especially having the all the harnesses at hand.
Old Jul 19, 2010 | 08:22 PM
sandmanf250's Avatar
sandmanf250
if it's an early 03 with the square egr put that on rather than the round one,or delete.the early square ones rareley had problems.like mine
Old Jul 19, 2010 | 08:24 PM
rickatic's Avatar
rickatic
I was remiss in not providing Cheezit's quote. He told me that back then as well. I reworked a 2006 van engine to put in my pickup. Thus Moes advice.
Old Jul 19, 2010 | 08:26 PM
rickatic's Avatar
rickatic
Sandman,
You have that reversed. The 03 has the round cooler, the 04 has the square cooler. I would say that the square cooler works quite well when combined with a coolant filter and properly managed coolant maintenance. It does not like to be starved for coolant
