Rear end gear ratio
Old Jul 18, 2010 | 06:15 PM
dustin.murdock's Avatar
dustin.murdock
Rear end gear ratio
If i change my rear end from a 3.50 gear ratio to a 2.75 will i be doing lower RPM's?
Old Jul 18, 2010 | 06:28 PM
Beechkid's Avatar
Beechkid
300 rpm change for each .25 gear ratio change.- Yes a 2:75 is taller thereby redcing rpm at the same given speed.- estimate approximately a reduction by about 900 rpm
Old Jul 18, 2010 | 07:16 PM
tvsjr's Avatar
tvsjr
And the transmission won't be happy, and your gas mileage will suffer because you'll have ZERO power in most any gear and will have to downshift to do anything.
Old Jul 18, 2010 | 10:24 PM
Ron/RPMS's Avatar
Ron/RPMS
your speedo will read slower too..........
Old Jul 19, 2010 | 12:05 AM
Hybris's Avatar
Hybris
You would be able to regain some power by switching to the smallest possible wheel that will still fits the brakes and go with the lowest profile tire you can get to raise your end gearing.
Of course with low pro tires there is a whole other world of issues.
Old Jul 19, 2010 | 12:51 AM
Ford Fx4's Avatar
Ford Fx4
that would be the last of his worries if he did such a thing
Old Jul 19, 2010 | 09:38 AM
shotgunz's Avatar
shotgunz
And this can't be in the right forum.
Old Jul 19, 2010 | 10:03 AM
3putt's Avatar
3putt
Ford engineers do a lot of work trying to get the best ratios between transmission and universal. IMO, one who lives in the hills or tows should have a 3.73. People looking for max gas mileage might consider a 3.5 or 3.35 but have to understand the truck will be chasing gears as one goes to lower numbers. As mentioned above, can't imagine what a 2.75 would be like.
Old Jul 19, 2010 | 04:46 PM
Ron/RPMS's Avatar
Ron/RPMS
True but just letting him know the whole picture.............Ron
ocala562
1997 - 2003 F150
Jan 11, 2011 05:03 PM
fastestbbc
Nov 20, 2008 07:56 AM
shooterguns
Nov 29, 2006 02:09 PM
johncfox
Aerostar
Aug 15, 2004 01:47 PM
NMStang218
1983 - 2012 Ranger & B-Series
Aug 16, 2002 12:22 AM
