Whistling noise?
Old Jul 18, 2010 | 12:55 PM
mxnick824's Avatar
mxnick824
Whistling noise?
Pulled my 10k 5er this weekend.
I got a f350 auto. Start climbing the mtn and after the truck is runnin 3grand for a min it starts whistling like im loosing boost from somewhere and it also sounds like it does when u are going down a hill and the truck downshifts to use turbo assist? anybody know what this could be and how i fix it.
Old Jul 18, 2010 | 02:13 PM
brickie's Avatar
brickie
Could be a number of things,a crack in one of the exhaust flex joints that can normally be seen as soot on the firewall.It could also be a crack in a CAC tube blue boot,I would suspect that one or the other is what you are hearing.
Old Jul 18, 2010 | 03:28 PM
mxnick824's Avatar
mxnick824
CAC? and if one of those is the issue would i hear it all the time? this is the first time i have heard it. and it seems to only do it when alot of boost is being made. (pulling 10k uphill)
Old Jul 18, 2010 | 03:30 PM
cheezit's Avatar
cheezit
fan belt slipping?
Old Jul 18, 2010 | 03:37 PM
mxnick824's Avatar
mxnick824
Is that common? would make sense as the noise im hearing. it sounds identical to the tranny downshifting while "Braking" but the rpm do not move. as soon as i let out of it it stops?
Old Jul 18, 2010 | 03:43 PM
cheezit's Avatar
cheezit
well pulling a trailer would make the fan come on more. so the thing here is does it seem to happen as the fan comes on.
I cant hear the noise from here so its all a guess. but yes common enugh.
Old Jul 18, 2010 | 03:54 PM
olfordsnstone's Avatar
olfordsnstone
I will watch this thread as I am awaiting some mods on my truck and my whistle just may disappear (egr related). If it does, I'll post up what I did to make it go away. Although I'm sure there are more than one possible causes for this type of sound, it wouldn't hurt to log various fixes to the problems to help others.
Here is the link to the tea kettle type whistle that I am experiencing, and hopefully am in the process of fixing. We'll see.
https://www.ford-trucks.com/forums/6...eavy-load.html
Old Jul 18, 2010 | 04:14 PM
mxnick824's Avatar
mxnick824
Not sure if the fan is coming on or not? how would i tell
Old Jul 18, 2010 | 04:54 PM
mxnick824's Avatar
mxnick824
Sounds like this is a common issue on here? It would make sense that it is the belt but it sure sounds like an air whistle not friction(belt)
Old Jul 18, 2010 | 08:22 PM
mxnick824's Avatar
mxnick824
I also had this issue comming down the mtn. when the rpms reached 2700+. 3rd? Would that make more since that it was the belt? Since im not in the gas. but it is still at high rpms?
themaniam1
6.4L Power Stroke Diesel
Jul 26, 2014 11:07 PM
Saxon
Sep 5, 2012 05:38 PM
OneTon4Fun
Dec 1, 2011 01:19 PM
vpsr6
2004 - 2008 F150
Dec 24, 2008 05:31 AM
The Grinch
May 27, 2008 03:22 PM
