need help ID carb
Old Jul 17, 2010 | 09:44 AM
low54's Avatar
low54
need help ID carb
hey all,
I posted this on the Y-block forum, but set the link here too, Could I have some help Identifying this carb...follow the link for pictures thanks...
https://www.ford-trucks.com/forums/9...ying-carb.html
Old Jul 17, 2010 | 10:46 AM
low54's Avatar
low54
Well, i did some searching, and on Timmy's yblock page i identified the carb as a autolite 4100, it has 1.08 venturies which makes it a 480 cfm unit...This was timmy's shpeel...:
Autolite 4100
A Ford design that looks similar to a Holley, this carb is a very underrated choice. Coming in sizes useful for a Y, the 4100 uses Holley jets and power valves. The annular discharge booster venturis are very efficient. A great choice for an all-Ford ride, the 4100 is simple and reliable. 3 sizes were made: a 480 cfm unit uses 1.08”venturis, a 600 cfm unit uses 1.12” venturies, and a rare, 1958-only version came with 1.19” venturis for 650 to 670 cfm. Check the carb base for venturi size numbers.
Old Jul 17, 2010 | 02:37 PM
52 Merc's Avatar
52 Merc
On the side of the left front foot, at the mounting flange just in front of the throttle linkage, you may find a series of numbers and letters, similar to a Ford part number prefix. That will give you an original application code. Take a look and let us know what you find.
