Leaf Springs
Old Jul 17, 2010 | 02:09 AM
mjshagnasty's Avatar
mjshagnasty
Leaf Springs
I am thinking about raising my truck and i was wondering how hard it would be to just add leaves in order to do it. I mean is it as easy as just throwing a couple of packs together in order to achieve the desired effect or am i just completely ignorant on the topic. The truck is a 1969 F-250 Highboy with a 360.
P.S. Are the front springs supposed to be nearly flat. It has been bugging me ever since i got the truck from my uncle.
Thanks in advance,
Michael
Old Jul 17, 2010 | 06:18 AM
xstrange's Avatar
xstrange
There are shops around that specialize in repair and rebuilding truck leaf strings. They have a process called "re-arching" which essentially means bending in more curvature. This is done with a big honkin' press and special dies.
If you add more leaves, you'll make the springs stiffer. This may raise the truck up somewhat, but you'll pay a price. It'll ride like an empty dump truck. The better approach is to keep the spring rate the same, but gain the height by re-arching. For ride and stability, a higher arch spring of the right spring rate is better than any add-on boosters or long shackles.
Take the springs off the truck and carry them into the spring shop. They can repair, rebuild, and re-arch your springs to whatever you need. And it isn't that expensive. That's what they do.
Old Jul 17, 2010 | 08:10 AM
mjshagnasty
Thanks I'll have to look around for a shop.
michael a
Feb 9, 2015 04:41 PM
MLBaranowski
Nov 13, 2014 09:58 PM
lilpro
Feb 11, 2010 12:30 PM
lilpro
37
Nov 6, 2006 01:16 AM
mike2755us
2004 - 2008 F150
Nov 1, 2006 09:55 PM
