Door emblem
Old Jul 17, 2010 | 12:32 AM
ccbrett's Avatar
ccbrett
Door emblem
Hey can anyone tell me what year this emblem is from my EX is a 03 but from what im told they didnt come with the powerstoke door emblem i need one for the other side i ordered one from ford but it is wrong. Thanks
Old Jul 17, 2010 | 04:17 AM
mark996's Avatar
mark996
They were used on 2003 models per the websites I came across. I found them for $34 for one, but found 2005-2007 emlbems for 39, so why not get 2 new ones from 05-07?
2005-2007 Power Stroke V8 Turbo Diesel Emblem
2003 Power Stroke V8 Turbo Diesel Emblem
Hope this helps some bud.
Old Jul 17, 2010 | 02:19 PM
2003 EXCURSION's Avatar
2003 EXCURSION
Here is a link, if I do this right.... This was posted on here somewhere a while back. I have an '03 also, but put the '05 emblems on mine, I just liked them better. BTW, I believe that all excursions were originally totally de-badged, so the emblem that you have on yours was probably added at some point. Mike
Diesel Emblems, Ford Power Stroke and International Emblems
Old Jul 17, 2010 | 05:20 PM
hwybee22's Avatar
hwybee22
Pretty sure that the emblems did not come stock on your X. When I purchased my X, I thought the same thing.
Old Jul 18, 2010 | 01:12 AM
ccbrett's Avatar
ccbrett
Ok cool thanks for the help I think ill just remove the one i got now whatr kind of problems with my paint can that cause and any ideas on taking it off.
Old Jul 18, 2010 | 07:57 PM
71-4R3SONS's Avatar
71-4R3SONS
Originally Posted by ccbrett
...any ideas on taking it off.
Yep... This works like a charm... Use a hair dryer and heat up the emblem... since the emblem is mounted on with double stick tape (it should be), the heat will release the adhesive and it will pull off with no problems. I've used this method numerous times to remove emblems as well as those stupid dealer emblems.
If needed use 3M General Purpose Adhesive Cleaner # 08987 (15 oz spray) to remove any residue. BTW... this cleaner is the BEST at removing tar too... prior to using a clay bar.
MY MODS
Old Jul 18, 2010 | 10:48 PM
katiesdad7's Avatar
katiesdad7
I don't think the emblems came with the EX. I got mine from ebay.
Ford F250 F350 Power Stroke Powerstroke Diesel Emblems: eBay Motors (item 260301941125 end time Aug-08-10 12:16:12 PDT)
Also, dental floss will take them off.
Old Jul 19, 2010 | 09:45 AM
boertje's Avatar
boertje
The X came badge-less from the factory. I put the stock emblems on mine that was equivalent for the F series PSD trucks of the same year. Makes it look more authentic. However, as for the 03 badges, I'd rather go with the 05-07. They look way better.
jh225
6.7L Power Stroke Diesel
45
Mar 11, 2014 10:38 AM
SD Dually
Jan 14, 2014 07:34 PM
ZSK
Oct 18, 2013 06:45 PM
FERacing66
May 3, 2006 06:43 AM
airharley
15
Apr 24, 2002 06:50 AM
