Axles issue
Old Jul 26, 2010 | 10:49 PM
Broomfieldbum's Avatar
Broomfieldbum
Actually it says rear, but I later found a picture like the one you posted, and I am speaking about the part described as Bearing Retainer. Mine is nearly flat. Not cupped like the one in your picture. I just posted the pict from my parts book in my gallery.
Old Jul 26, 2010 | 10:50 PM
Broomfieldbum
Thanks for the picture Bill, the seals are most likely still in the axle.
Old Jul 27, 2010 | 06:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Broomfieldbum
Look in my album for the picture, under Cooper. I found this picture in the parts book, and the part I am having an issue with is the 4020 retainer. Mine does not have the cup shown here. It is flat more like the 1001, (I know the 1001 is a gasket) I am just saying the part that is meeting the purpose of the 4020 on my truck is flat and there is no cup to hold the seal. Is this normal in a 66 9" rear end??
C6AZ4020A (replaced A8AZ4020B) Axle Bearing Retainer: 1957/72 9" Passenger Cars, F100's & 1966/72 Bronco's.
DOTZ4020A .. Axle Bearing Retainer / 1970/72 F100: Use with Ford WFF H/D 9" rear axle that has a 9 3/8" ring gear, Limited Slip and 31 spline axleshafts.
Have you counted the axleshaft's splines? A PO might have installed this rear axle in your truck and ONLY five internal parts are the same as a 9 inch.
Housing gasket, one pinion bearing and race, pilot bearing retainer and the pinion seal. Everything else is different including the axle seals..and the axle bearings.
patience
20
Oct 14, 2015 07:19 AM
overlandexpress
13
Jun 22, 2011 12:07 PM
Dano78
27
Apr 17, 2011 04:08 AM
victorspecial
Mar 4, 2008 08:22 AM
mgoovaerts
Jan 7, 2005 10:27 PM
