am wire harness
Old Jul 20, 2010 | 09:03 AM
turbochargedford's Avatar
turbochargedford
am wire harness
do they make an aftermarket wire harness for a 1962 f100?
Old Jul 20, 2010 | 09:40 AM
Broomfieldbum's Avatar
Broomfieldbum
There are many different harnesses, but I choose the EZ-Wire. It has every wire marked every 6 inches so it is really simple to install. I got mine from Goldenrodtronics.com less than $200.00 for a 12 wire, and a little more for a 18 circuit that has dedicated circuits for power windows and other modern features.
Old Jul 26, 2010 | 03:17 PM
unibody62's Avatar
unibody62
I don't believe anyone makes a direct factory replacement, but I read that many others have used this brand.
Since you guys are talking about it, what did you use to replace firewall grommets to give it that finished look?
Old Jul 26, 2010 | 03:37 PM
daveengelson's Avatar
daveengelson
Only found reproduction harness for 64-67 F100's; unfortunately have not found anyone who repro's the dash harness.
Old Jul 26, 2010 | 07:02 PM
Broomfieldbum
Firewall Grommets
I bought a set of aluminum rings, (think large washer) they came with rubber behind them, and it made a decorative piece. I hope I placed the picture right, it is of the ring above the 2 holes. I cut out the center tab, and then covered it with the ring, and put another one on the inside. All my wires run through this hole.
Old Jul 27, 2010 | 10:03 AM
unibody62's Avatar
unibody62
Okay, Not a bad idea. I may take that and add my own spin to it.
Thanks
SuperSnake
North Carolina Chapter
48
May 14, 2007 09:24 AM
88grandmarquis
Dec 1, 2002 10:21 PM
Diesel Steve
Electrical Systems/Wiring
Sep 4, 2002 08:54 PM
lshort
Apr 2, 2002 12:00 AM
jml
Jan 25, 2002 07:06 PM
