MPG increase
Old Jul 20, 2010 | 09:33 PM
JohnMcD348's Avatar
JohnMcD348
Wow, right now I'm only getting about 13-14mpg with my '93 EFI 300 in the Bronco. I just did a tuneup/timing bump on it and I'm hoping to see some changes. Either way at 14mpg, it's still my econobox compared to my DD. I know I have some emissions issues also but I'm working my way through them to try and figure out the ultimate cause. Hopefully I'll have a clean burning, 18+mpg Bronco in the coming months.
Old Jul 21, 2010 | 09:14 AM
Tees77f150's Avatar
Tees77f150
I was doing battle with my Cater 1 bbl on my 77 300, and was getting between 10 to 14 mpg. I would fine tune it, and it would run good, but in no time it just wasn't running right, and there was an ever increasing rich problem. I would adjust the fuel/air screw, but it made no difference. I took the carb off, and found this screw was broken off in the carb.
I got a friend who is in the surplus business, and he had a Cater 1 bbl brand new in the box, however, I learned it was for an 81 to 86 F150, 84 Topez, or 86 Mustang. I put it on and it ran like a NEW truck, but with in 15 to 20 minutes it started to run like the other carb, or worse. I got a rebuild kit, and that took care of it, and I took it to my buddies shop and he put it in the scope and we fine tuned it, and I am now getting 19.5 mpg.
One of the other up grades is it now has an electric choke, which makes it nice too. I figured in four tanks of gas, I will save in gas to pay for the carb, which was $75 by the way. I thought that was a decent price for a carb that had never been on an engine before, and when the carb was rebult, the biggest issue with it was the float was WAY out of adjustment.
Old Jul 21, 2010 | 11:49 AM
Harte3's Avatar
Harte3
That right there can cause quite a bit of grief. The idle usually sucks when the float level is not right and no amount of external adjustment can correct that.
Old Jul 22, 2010 | 02:28 AM
Tees77f150's Avatar
Tees77f150
Thumbs up
Your right, I felt as if it was going to shut off at any time, it was very hard to drive in that condition. It now comes off of the line and right up to 55, or 65 mph with the rest of them now with ease.
Old Jul 22, 2010 | 09:39 AM
F-250 restorer's Avatar
F-250 restorer
ZF with Gear Vendor...
I am intriqued by the gear-splitting ability of the Gear Vendor unit with a ZF. Looking at the chart on the GV site, I could see how it would be very useful for climbing with a load, also for keeping the rpm in the torque band for better mileage.
Would it be over-kill? Maybe.
Old Jul 22, 2010 | 05:57 PM
flipklos's Avatar
flipklos
You priced a gear vendors torque splitter?
They are quite spendy.
A 3.90 rear and a ZF would give you sufficent torque and milage for all but the heaviest loads.
Old Jul 22, 2010 | 06:24 PM
dustybumpers's Avatar
dustybumpers
would be very pricey to do, and an awful lot of fab work to get it all together, to make something that only you would understand, and appriciate. let alone, I really think the driveabulity would really be horrable.try driveing a zf equiped truck with 4.88's in it, the shifting happens so quick, your in 5th, before you are hardly out of the intersection, now split it, and that's a whole lot of shifting. the trucks manners would be horrable.pulling a heavy trailer would be bad, you would be shifting constantly.
Old Jul 24, 2010 | 11:12 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Originally Posted by Econoline 150
I don't know how traffic is where you live. I do know if you have alot of stop and go and backed up freeways standard shift can be a PITA.
I once drove my 4 speed 81 through ungodly Atlanta traffic to help move my daughter back home. If I lived there I would not have a standard shift !
Its not too bad once you get used to it, Ive commuted 180 miles a day for almost a year through atlanta and you learn to run in a low gear like the trucks and **** everyone off behind you.
Old Jul 25, 2010 | 10:13 AM
oldbrokecowboy's Avatar
oldbrokecowboy
Some things come with unexspected perks. OBCB
Milwaukee1979F150
1978 - 1996 Big Bronco
38
Jun 3, 2017 05:08 AM
deisele75
Alternative Fuels, Hybrids & Mileage
18
Jul 2, 2016 06:12 AM
F-250 restorer
53
Oct 23, 2011 02:41 PM
F-250 restorer
May 1, 2011 04:32 PM
Irish Wake
6.4L Power Stroke Diesel
Nov 27, 2010 09:55 AM
