AC problems
Old Jul 16, 2010 | 06:50 PM
jwarrenclements's Avatar
jwarrenclements
AC problems
I have a 1990 F350 diesel. The AC coil has no continuity across the terminals. I want to change the coil but am experiencing the following problem. I took off the clutch plate by removing the nut and using a puller. I then removed the clutch by removing the snap ring and pulling it off. The problem is that I can't see how to get the magnetic coil off. Anybody got any suggestions?
Old Jul 16, 2010 | 07:05 PM
carolinaranger90's Avatar
carolinaranger90
I have no idea if this is any help......but I figured it'd be better to show you then to let this thread go to waste with no help for ya.
Hope it helps man.
How to Replace a Compressor and Clutch | eHow.com
Old Jul 16, 2010 | 08:44 PM
redlightning93's Avatar
redlightning93
I believe that coil is pressed on and will require a puller to remove it.
Old Jul 16, 2010 | 09:10 PM
carolinaranger90
the link I included described that I believe........
Old Jul 17, 2010 | 10:13 AM
redlightning93
Touche'.....
KaeGee
Feb 26, 2015 09:06 AM
expguy121
Aug 30, 2012 09:40 PM
pcmpete
Aug 6, 2011 08:40 PM
pcmpete
Escape & Escape Hybrid
Aug 3, 2011 12:33 AM
Frdf150
Jul 17, 2003 07:51 PM
