Cold vs Warm air intake
You guys can suck hot air all you want, I know cold air makes more power so you'll never see an open element filter under my hood.
anyone thought of plumbing strait into the cowl ?? or strait up through the hood ?? i know thats a low pressure area, but just thinking
I noticed a slight advantage by switching to a K&N drop in w/ my 87' 302, But with sidegap plugs gapped .012 wider than stock, that's about as much extra air as I dare. My HC output is .01 ppm. That I think, means I'm may be a little too lean. A side note, I'm running 16 BTDC. Thinking about experimenting w/ 89 octane but it doesn't seem to like 91 at all. It will run once it starts, but doesn't want to start. But I do get over 20 MPG hwy w/ 87 octane.
We also had a KN FIPK on a 1997 Mustang Cobra, and it did nothing good for the car. Under normal driving conditions for daily commuting, the mileage dropped 3 mpg or more.
If warm underhood air was good then why would anyone want ram air or a hood scoop to draw in outside air.
I'll stick with my stock air box, paper filter, and I6/460 tube.
Also, if open element filters made vehicles run more efficiently then many of them would be coming that way from the factory, since it would help with efficiency and help them meet the regulations.
As i know in carb engines you need to heat the TB or intake to make the air fuel mixture vaporize instead of fuel "drops" in the air so you have better mixture and better combustion. I dont know if is the same for fuel injected engines.
The guys at the drag strip also say their cars run better when its cool outside. They have time slips to show it.
That cooler air is better is based soundly on simple physics & not really up for debate.
Now, go to air flow. Theoretically, more air is going to produce more HP. Now enter the ECU & it's ability to sense operating input & mod the air/fuel trim to accommodate.
MAP sensor only engines, do not & can not identify the amount of flow, therefore, if air flow is increased to an amount above it's fixed ability to accommodate, you are now uncontrollably over lean! Some people attempt to compensate by increasing octane. Bad Idea. While reducing combustion chamber temps., incomplete ignition is the trade off. Eventually octane must again be increased to run ping free. Till you run out of higher octane options.
Now, MAF engines do actually allow the ECU to accommodate for increases, to a much greater extent & fuel trim is based on actual air flow, but still, cooler is more advantageous.
I guarantee factory designed CAI's are not based on what was laying around at the time the engine was assembled. They have been & still are the method of choice the factory employs to de-tune the engine. But if your MAP only, your options are severely limited by reason of the limitations of the senor. The ECU already has you running at 14.68:1 to start with!
Does everybody know that their engines come intentionally "de-tuned" from the factory? Which is why increasing stock air flow (on engines capable of adapting), bumping stock timing, upgrading Ignition systems to allow increased plug gap & ECU Mods enhance performance?
Why don't they just come like that off the show room floor? Because optimum performance demands optimum maintenance. Preventative as well as when required. History tells them as a rule, that ain't going to happen when they sell the vehicle to John Q. Public. And they are correct! The term Found On Rroad Dead was very popular before detune began. This also coincided w/ Emmissions control implementation.
Personally, I run 87 octane, a 60K volt coil. A side gap copper core plug gapped .012 over stock. 16 BTDC. All synthetic fluids. I leave my Code Reader plugged in under the hood & test regularly. I use a K&N drop in filter in the stock factory CAI. Performance is above average & reliable. Over 20 MPG. How much more can I ask from an 87' 302 daily driver?
That is where most Lightning CAIs are routed and I dont think it would be any warmer than the stock airbox. I would do it myself but I dont have a thermometer.
Im just wondering how big of a difference in air temp there would be with an Open elements filter right by the grille opening compared to inside the stock airbox.
