How do I stop the beeping?!?!?! PLEASE HELP!!!!
Old Jul 16, 2010 | 02:27 AM
gmbtowing's Avatar
gmbtowing
I have a 2005 Fx4 supercrew with a beeping problem. The door beeper goes crazy every time I open the door and sometimes it does it when I'm going down the highway with the doors closed. I just want to remove it. Please help. This is driving me crazy!
Thank you!
Text me if you can help 219-781-0709
Old Jul 16, 2010 | 07:38 AM
Deluxe05's Avatar
Deluxe05
There are several reasons that you may be getting "dinged" at:
  1. Key-in-ignition warning chime: Sounds when the key is left in the ignition in the OFF/LOCK or ACCESSORY position and the driver’s door is opened.
  2. Headlamps on warning chime: Sounds when the headlamps or parking lamps are on, the ignition is off (the key is not in the ignition) and the driver’s door is opened.
  3. And then there is the BeltMinder. This will sound when either the driver's or front passenger's seat belt is not buckled AND the vehicle has reached at least 3 mph (5km/h) AND 1-2 minutes have elapsed since the ignition switch has been turned to ON.
I am not sure that much can be done for the first two in that list short of finding & unplugging whatever makes the warning sounds. However, there is a procedure in the 'Seating and Safety Restraints' section of your owners manual for disabling the BeltMinder feature.
If you do not have your owners manual, you can download one at http://www.motorcraftservice.com/.
Old Jul 16, 2010 | 09:20 AM
hcbph's Avatar
hcbph
Beeping
Don't know which sound you're getting (of the 3 listed earlier) but if this is happening as soon as you open the door (even when the truck is turned off) I'd guess it's the ignition alarm (key in the ignition). Sounds like you may have one or more switches/sensors that are causing issues. That's the first one I'd look into if it happens when the door is opened and the key is not in the ignition.
Paul
Old Jul 16, 2010 | 11:13 AM
gmbtowing's Avatar
gmbtowing
Also, My odometer doesn't work
Old Jul 16, 2010 | 10:32 PM
Greg B's Avatar
Greg B
Where at in NW indiana are you, gmbtowing? I'm in South Bend. How old is the battery? Check it for condition. We had similar issues with my wife's Taurus. A new battery cured it. That was after I tried running down the problem and finding nothing wrong. When the battery finally did die the warning chimes were going crazy. It turned out that the PATS system was actually setting off the chimes everytime that the door was opened. I don't know if that's your problem or not, but it's a place to start. After I read thru the Ford shop manual several times, I learned that the PATS system can do weird things under some conditions and that the GEM (generic electronic module) controls the PATS and warning chimes.
Old Jul 17, 2010 | 12:26 AM
mikesheldon's Avatar
mikesheldon
Someone set it up in "kid zone" mode. It is a common feature so that parents know when a kid (usually infants) exits the home with no permission.
Read the user manual on how to exit that mode or call your alarm company and they can help you.
Old Jul 17, 2010 | 01:42 AM
gmbtowing's Avatar
gmbtowing
Where does the beep come from? I just want to remove it
Old Jul 17, 2010 | 07:19 AM
Coskid's Avatar
Coskid
Removing won't be an option because of how they have hooked everything together you just have to figure out to turn it off or disable the alarm.
Old Jul 17, 2010 | 08:09 PM
Greg B's Avatar
Greg B
The beeping is coming from the GEM and it can't be removed. As Coskid said you'll have to change the settings. Your owner manual should tell you how to do that. But make sure your battery is good also. A battery that's bad or going bad can cause that as well.
jterrell
76
Oct 16, 2017 04:18 PM
bo33111
Jan 25, 2016 04:49 PM
shadyEats
1983 - 2012 Ranger & B-Series
13
Jun 15, 2015 02:00 PM
hmbrewr
6.7L Power Stroke Diesel
Jul 6, 2011 06:17 PM
John7894
Jan 4, 2005 01:33 PM
