4R70W Update Advice?
Old Jul 15, 2010 | 11:16 PM
nashaj's Avatar
nashaj
My 106k mi, 95 F-150, 5.0, 4r70w, 4x4, has a harder than normal shift from 1st to 2nd and a whining noise while in park. From research I have discovered the most common cause for the hard shift is the 1-2 accumulator spring. I've decided while I'm in there replacing this spring, I'll go ahead and replace the valve body with an updated one from BCA home ,maybe, havent decided if this is the one I'm gonna go with yet.
I would like to update as much stuff as possible while I have the valve body off. What else is worth updating or replacing?
Any other advice you can give will be much appreciated!
Thanks in advance
Drew
Old Jul 16, 2010 | 08:07 AM
carolinaranger90's Avatar
carolinaranger90
While you have the transmission out re-seal the whole thing, and drop some synthetic in it, my friend was having a lot of problems with his E4OD about a year and a half ago, same kinda stuff you were talking about, a whining/rubbing noise in park, either struggled to shift from 1st to 2nd or instead of struggling it slammed into the gears, he pulled it out and re-sealed the entire thing, and ran some Royal Purple ATF into it, to this day, it still shifts like a dream and has given her NO problems.
Old Jul 16, 2010 | 08:09 AM
carolinaranger90
I didn't realize you lived in Cheyenne till just now, I'm working from 8-4 today, might get off early, not a lot of work orders lately, i'll PM you my number, call me if you need help.
Old Jul 16, 2010 | 08:43 AM
Conanski's Avatar
Conanski
Since both the engine and transmission are controlled by the same computer you want to make sure there are no sensor issues(codes) before laying a hand on the transmission. Have been guys here that have done a complete trans rebuild because of shift issues only to find out after that it was a sensor issue when the new trans did the same thing.
Old Jul 16, 2010 | 09:19 AM
CS45's Avatar
CS45
OUCH! That's an expensive learning curve.
CS45
Old Jul 18, 2010 | 10:30 PM
nashaj's Avatar
nashaj
I'm not pulling the transmission, I'm just gonna put in on a lift and pull the pan.
Old Jul 20, 2010 | 09:31 PM
nashaj's Avatar
nashaj
Yeah, I live near Pershing and Warren. Thanks for the offer to help
Old Jul 20, 2010 | 09:36 PM
nashaj's Avatar
nashaj
I'm not getting any codes on my OBD1 scanner.
I ordered the valve body today. Its comes with new accumulator parts and a new filter. I'm gonna flush the system and run AMSOIL synthetic.
I'll let you all know what happens!
kountzecobra
18
Jan 7, 2022 01:48 PM
drew2fast
Aug 14, 2015 07:16 PM
50dann
1983 - 2012 Ranger & B-Series
Apr 23, 2014 03:19 PM
JDpuller4010
Feb 11, 2014 09:12 AM
andyman91
Jan 29, 2014 11:05 AM
