Power at lighter plug....
Old Jul 15, 2010 | 08:01 AM
Unimog005's Avatar
Unimog005
In my 1967 F-250, I have a "lighter plug" on the dash covered with a small plastic cap....it has power, but......it seems incapable of charging my Blackberry.
A recent rental car I had was able to charge the phone via the charger in about an hour with the car off, yet....I can drive for an hour in the truck and the phone will barely get on bar of extra power.
Is this an "amperage" issue? Can I increase the power output of that plug by routing a larger gauge wire to carry the power?
Old Jul 15, 2010 | 09:43 AM
CougarJohn's Avatar
CougarJohn
The wire to the lighter is certainly capable of providing the current to supply a small hand-held device. You probably have an issue with the connection. Scuff up the connections with emery cloth and try again.
Old Jul 15, 2010 | 10:50 AM
Unimog005's Avatar
Unimog005
That's an idea....I don't think I've cleaned that one up yet....
Old Jul 15, 2010 | 11:05 AM
Rusty 63's Avatar
Rusty 63
I'd almost guarantee that if you stuck your finger in the lighter socket & swirled it around you'd have a rust colored finger. Grab a piece of emery cloth, wrap around your finger & do it again. See if that helps. If you get any crazy ideas of using steel wool, disconnect the battery first! Steel wool + 12v = fire starter! Great for survival purposes - not so nice inside your cab!
Old Jul 15, 2010 | 12:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Replacement lighter sockets and elements are still avaliable and relatively inexpencive. Might be a better option to cleaning.
Old Jul 15, 2010 | 02:52 PM
xstrange's Avatar
xstrange
Another good thing for cleaning it out is a wad of Scotchbrite, green, maroon, or grey. It's abrasive, non-conductive, and will leave less mess inside.
Maybe it's just me, but there's something very amusing about using a '67 Ford pickup to charge a Blackberry. A clash of civilizations....
Old Jul 15, 2010 | 05:10 PM
4x4jedi's Avatar
4x4jedi
Too funny. I'm doing all I can to hide all tech stuff in my truck. I hate seeing 2010 tech in a 1970! Can't live withought it though. I love my Iphone
Old Jul 15, 2010 | 06:00 PM
jowilker's Avatar
jowilker
I was thinking about powering up a Droid X in my truck, think it can handle it?
John
Old Jul 15, 2010 | 11:50 PM
xstrange's Avatar
xstrange
Originally Posted by jowilker
I was thinking about powering up a Droid X in my truck, think it can handle it? John
Are you kidding? The Droid would be a smoking puddle and your Ford would keep on rumbling down the road.
I was thinking about a window sticker that says No Computers On Board.
That's a big part of the joy of owning one of these old trucks. It's simpler, older technology. I was demonstrating to a friend the other day the beautiful sound that you get when you slam the door on my '67 F100. It goes BWAAANGGG with sweet harmonic overtones. His stupid Beemer makes a boring little "thump". Yawn.
Old Jul 26, 2010 | 08:06 AM
Unimog005's Avatar
Unimog005
Ok....need another idea....this inside of the plug is shiny clean....not a lick of rust....but, still very low amperage apparently....
Old Jul 26, 2010 | 08:30 AM
CougarJohn's Avatar
CougarJohn
It's not an amperage problem. That hand-held draws practically nothing in the charging circuit compared to a lighter draw.
Are you sure you have 12.6v at the socket? Like, no blown fuse? Are you sure the hand-held will charge off 12.6v and that the charging plug us compatible?
This one is a head scratcher.
Old Jul 26, 2010 | 09:59 AM
Unimog005's Avatar
Unimog005
I need to read the plug and see....I am basing my comparison on using the same charger and device in a rental car...in that case, the car was OFF, but had a "lighter plug" that remained hot....in that case, the Blackberry charged from nothing to full in about an hour....about the same as the 120v charger does....but in the truck...even driving at highway speeds, 1.5 hours only gives 1/4 charge....if that....
Old Jul 26, 2010 | 03:00 PM
xstrange's Avatar
xstrange
Yes, your problem is most likely voltage, not current. I'm pretty sure that insufficient voltage would make the Blackberry's charger work slower like that. So, somewhere in the circuit there's too much resistance, which is causing the voltage at the input terminals of the charger to be too low. This could be as simple as corroded contacts at the fuze or in one of the crimped wire terminals. It could also be tricky to identify. For example, when you poke your meter probes into the terminals of the receptacle, you might read 12.6V, but the terminal might not be making full contact with the terminal on the chargers' plug.
Or, your truck might be subtly trying to discourage you from using your Blackberry. They're wise old trucks....
Old Jul 26, 2010 | 03:21 PM
CougarJohn's Avatar
CougarJohn
Plug your gizmo charger into the 120v wall socket and check the dc charging voltage at the gozinta receptacle. Your unit may want more than 12.6v to charge and this is the way to find out.
Old Jul 26, 2010 | 05:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It has power, but......it seems incapable of charging my Blackberry.
This socket is not original to the truck, it prolly came from an autoparts store. This type of socket was not offered by FoMoCo until the 1990's.
And...since it's not original, who knows how it was wired in?
The original lighter socket used in these trucks has a barrel shaped fuse that threads onto the backside of it.
Most people (especially in today's world) have never heard of this fuse, are totally unaware that it's there.
The fuse has one male, one female end. The female end threads onto the stud that is part of the lighter socket, then the wire plugs onto the male end.
FEW14429A .. Lighter Fuse / Obsolete
Fits all: 1956/72 FoMoCo Passenger Cars, Trucks, Bronco's and Econolines.
GREEN SALES CO. in Cincinnati OH has EIGHT = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has EIGHT = 563-562-3241.
TISON MOTOR CO. in Estill SC has TEN = 803-625-2551.
MILLER OBSOLETE PARTS in Binghamton NY has ELEVEN = 800-546-7278.
The factory installed fuse has a hole in it. By using a paper clip (or similar), the fuse can be reset. The replacement fuse has no reset hole.
OkLaHoMaF150
1997 - 2003 F150
Jul 22, 2014 02:08 PM
1979 300i6
Jul 20, 2013 09:04 PM
rhino_160
Jun 18, 2008 04:14 PM
tmoney67
2004 - 2008 F150
Aug 26, 2005 04:22 PM
jhromy
Jul 10, 2004 01:08 PM
