Using lighter socket as power outlet
Old Aug 14, 2005 | 09:01 PM
tmoney67's Avatar
tmoney67
I noticed in the owners manual of my 05 F150 that you are not to use the cigarette lighter socket as a power outlet. You are only to use the power outlet provided. What's up with this?? Is there a reason you can't charge a cell phone or plug in a GPS unit or anything else for that matter?? Will I harm the trucks wiring or ruin my electronics by using this?? I don't plan on using an inverter or anything that draws alot of juice. I don't smoke so it would be nice to take advantage of that as a 2nd outlet. Do you guys use it as a power outlet?? Any problems? I need some advise and I know you guys are full of it, um, advise that is Thanks!!
Old Aug 14, 2005 | 11:35 PM
Birdhunter1's Avatar
Birdhunter1
I have my cell phone charger plugged into it all the time, have done it for a little over a year and have had no problems as of yet.
I'm sure if there was going to be a problem it would have happened by now.
Old Aug 14, 2005 | 11:59 PM
4x4twinkie's Avatar
4x4twinkie
I have my rotators plugged into my cigarette lighter and have not had any problems. So, Im sure if thre was a power problem it would have happened already.
Old Aug 15, 2005 | 12:44 AM
ford390gashog's Avatar
ford390gashog
there is no problem as long as you stay under 120 watts. the power outlet is a 20 amp socket
Old Aug 15, 2005 | 09:04 PM
kingfish51's Avatar
kingfish51
One thing I remember is one of the car magazines in their 2004 F-150 test story is that had a problem with the lighter in the test vehicle, dealer told them not to use the lighter as a powerpoint. They had never heard of such a thing, and of course they never bothered to read the owners manual. Don't remember what they were powering with it.
Old Aug 16, 2005 | 06:18 PM
Crownie's Avatar
Crownie
I know that it is supposed to be taboo but I've done it many times with my last three Ford trucks without incident. Need that radar detector and power for the cell phone or the kids portable DVD players.
Old Aug 16, 2005 | 07:06 PM
tmoney67's Avatar
tmoney67
Thanks alot for the info.
Old Aug 16, 2005 | 07:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
The lighter socket is slightly larger than the power point socket in terms of diameter.
Many electrical items will adjust to the larger size of the cig lighter (some even have the manual adjustment feature) but due to insurance regs and what-not, Ford states not to use the cig lighter and to only use the dedicated electrical power point to power your devices.
Old Aug 16, 2005 | 07:17 PM
oldRedTruck's Avatar
oldRedTruck
so for non smokers (myself included for 8.5 months) a quick mod would be to swap out a junker's power outlet into where your cigg lighter is
I'll have to remember to grab one next time I'm at the yard!
Old Aug 16, 2005 | 11:03 PM
ReForder's Avatar
ReForder
my radar is plugged in there, no problems ever. i've done this in all my cars. However, i hate the fact that it stays hot all the time, all the 12V outlets do. I find this annoying, cause i'm too lazy to turn off my satellite radio or radar detector.
Old Aug 18, 2005 | 03:36 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sorry...I said this backwards. The power point is slightly larger than the cig lighter.
Old Aug 18, 2005 | 04:01 PM
aquaman's Avatar
aquaman
Both cig lighter and power outlet are wired with 16AWG wires directly to 12V. Personally, I wouldn't try to pull to many amps out of it for very long. Technically there's no diff between the two. Maybe the cig lighter is considered taboo because if you have stuff hangin there, it'll get in your way as the driver more easily than the power outlet.
I'm tempted to replace the thing with a 120VAC 3-prong receptacle that runs off a 700W inverter stashed somewhere else inside or under the dash. Problem is I haven't found anything that will fit in the hole and still look stock.
any ideas out there?
Old Aug 18, 2005 | 06:55 PM
shock1wsu's Avatar
shock1wsu
I just went on vacation and had one of the kid's DVD players hooked into the cig lighter. I did notice some interference in the radio - not static- but intereference. When we stopped for lunch, I moved the DVD to the power outlet and no more intereference.
Old Aug 26, 2005 | 09:21 AM
snydersc's Avatar
snydersc
I used my cig lighter for portable air compressor. Accidentially pulled the cord too tight and it managed to pull the assembly out of the dash, and blew the fuse. The problem is that it just snaps into place and could be easily damaged. just my 2 cents.
Shawn
Old Aug 26, 2005 | 04:22 PM
tmoney67's Avatar
tmoney67
I'm going to use the power outlet most of the time but mostly wanted to plug my cell phone or GPS into the cig lighter outlet. Thanks everyone for all the great comments and ideas.
lexustbs
6.7L Power Stroke Diesel
Jul 28, 2011 09:04 PM
megaede
Electrical Systems/Wiring
Nov 4, 2010 09:09 PM
rla337
Jun 15, 2009 09:35 PM
slkc
Dec 28, 2006 01:55 PM
