1978 - 1996 Big Bronco
1990 Bronco Check Engine Lite
Old Jul 14, 2010 | 08:32 PM
g_k50's Avatar
g_k50
The old Donko is running pretty good now that I've had a chance to test it out with the new fuel pump. There's still a few slips in the transmission in Overdrive, but I'm using Drive mainly.
The check engine light comes on after the engine is warmed up, during a deacceleration.
I've check the codes,
KOEO, 11, yea!!
KOER, 41, 52 Hmmmmm
CM, 41, 53, 33 Hmmmmmer?
The light will self extinguish if the engine is turned off, but eventually comes back on during a lull in acceleration, not that I have tried to avoid those lulls, (hahahaha).
Old Jul 15, 2010 | 12:59 AM
greystreak92's Avatar
greystreak92
Hmm... how about a page from your own suggestion book... give up and take it to a good mechanic.
Old Jul 15, 2010 | 07:25 AM
Encho's Avatar
Encho
The Southernmost Mod
Lol Grey... If i were you, g_k50, i would search for a loose wire or sensor, any of those could give that sort of signal, check the battery terminals also.
Old Jul 15, 2010 | 09:39 PM
g_k50's Avatar
g_k50
I can't afford to take it too a good mechanic, that's why I'm here. partially.
So I took it up the trail, here's how:
URL not working.
AWorley
Nov 18, 2012 08:34 AM
Slip ford man
Aug 6, 2011 08:53 AM
Ed
Oil & Lubrication
24
Jun 25, 2007 04:03 AM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 13, 2006 04:20 PM
TrucknFool
Apr 13, 2004 12:15 AM
