On my 92 302 I get the code 41, it seems like it's more of a problem during the heat of the day. The truck just runs poorly during that time with a continuous engine light on. How many possibilities are there as to the cause of a code 41...thanks for any help
You likely have a cracked exhaust manifold, a leaky air injection hose, tube, or valve, or a blown intake gasket. It's not likely at all you have a bad O2 sensor.
Thank's, could you explain why it would run good while cooler, and then run poorly later on.
At cold startup the computer runs in open loop on the factory programmed tables which are rich, once it hits operating temp it goes closed loop and uses feedback from the O2 to set the mixture. If the O2 sensor is working properly this would indicate there is an uncontrolled air leak into the exhaust that is making the mixture look lean, but this would also mean that the computer is at the rich adaptive limit and there would be a rich smell from the exhaust and gas milage would be poor. Do you have that problem? If not and instead the motor seems to run lean with poor power and a stumble or miss(plugs are white) it is possible that the O2 sensor is bad and is giving the computer bad info. When was the sensor last changed?
I have not changed it in the 3 years that I have owned it. Only one of the two sensors is connected, someone cut the leads off of one of them. I recently check the gas milage the other day it was 16 to the gal, but yesterday I'm sure it was poor, thanks again
quote
Thank you, what are the thermactor and CANP?...do you think that heating of the day would affect any of the 7 items that you listed? I guess that I need both oxygen senors connected as well?...thank you again
Thank you, what are the thermactor and CANP...do you think that heating of the day would affect any of the 7 items that you listed?...thank you again
No I do not. The 41 code may not have nothing to do with any of the 7 if it only has the problem when it is hot out. You may have more than one problem.
The heat of the day problem may be the air intake temp sensor or the water temp sensor.
Or it could be a fuel problem with low fuel pressure. That may be a fuel pump going bad and that could generate the 41 code.
