Injector line holders
Old Nov 5, 2010 | 11:59 PM
Sycostang67's Avatar
Sycostang67
Ouch, thats expensive. You really should stop in all the local junkyards and try to find an IDI. I got a complete set of lines and clamps for $11 from one yard. You can use the lines from a 7.3 or a 6.9 IDI. The #1 line is the only one thats really different between the two motors. Some of the other lines are bent differently but still connect the IP to the injector. The #1 line is shorter on the 7.3's since there is a timing adapter on top of the injector, but if you grab the timing adapter you can use it on the 6.9 as well.
Old Nov 7, 2010 | 06:29 PM
poocher pup's Avatar
poocher pup
could you just wrap each line in rubber hose and overlay with flat steel and bore holes in each end to bolt together, seems it could be cheaper.
Old Nov 17, 2010 | 12:29 PM
ttexastim's Avatar
ttexastim
UPDATE: Installed the new lines last night. Wow, I am very VERY glad that I replaced all driver side lines at the same time. Last time I replaced one, I had to actually bend it to get it to fit in the line holders. This time, they all fell right in line and putting line holders on was cake. Seems like it took forever to tighten up the #2 injector line on the injector since it was all the way at the bottom, but I had enough patience using that crow's foot socket on the end of a swivel 3/8 drive that I eventually got it.
Fired it up last night, and no leaks. Drove it to work today. I'll check it tonight and make sure there are still no leaks. It was awesome to hear the old truck roar back to life.
Old Nov 17, 2010 | 02:13 PM
wreckinball's Avatar
wreckinball
Hell man i could get you a set of 8 for half that! Wish i saw this thread sooner. Hope everything works out. Where the 8 line was leaking sounds like bad orings. Double check that and replace 7c orings before anything else but inspect the line while it is apart.
Old Nov 17, 2010 | 02:31 PM
michbol's Avatar
michbol
Has anyone ever heard of anyone fabbing up some flexible lines to replace the old hard steel lines? Seems to me it wouldn't be that big of a deal and would probably save $5-600 if you replaced all eight injector lines and the pump feed line.
Old Nov 17, 2010 | 02:36 PM
wreckinball
If you had a hydraulic place make them maybe.....maybe they would work but they would all have to be the same length and could not expand or flex with the injection pulse. I dont know that hydraulic lines flex like on a loader or similar but if they flex a little they are out of the question. I am all for it though. I have put alot of thought into it as well. It would look sweet to have stainless braided lines all over the engine!!
Old Nov 17, 2010 | 02:45 PM
michbol's Avatar
michbol
flex would cause the injectors to not pop... how much psi does the injector pump to injectors create?
Old Nov 17, 2010 | 02:55 PM
wreckinball
I think new injectors pop at 1600psi iirc or near there. I have never seen a hydraulic line on a loader flex or swell but they do rupture, i just dont know if something non rigid could take the pressure. but then again i dont know much about hydraulics.
Old Nov 17, 2010 | 02:58 PM
michbol's Avatar
michbol
having custom made steel braded hydraulic lines fitted for our engines would probably be a pretty expensive endeavor and would probably be prone to failure...
Old Nov 17, 2010 | 03:38 PM
wreckinball
Yeah i dont know how much better it would be over stock. I would say that you could get steel lines made to fit of a more durable type of steel. The steel from our systems, when stock, was made a long, long, time ago. But over stock, what added benefit vs price would we see, i am not sure.
Twilight Fenrir
May 29, 2013 06:10 PM
6.9idiatsturbo
Apr 23, 2012 07:57 PM
Franklin2
18
Sep 19, 2009 01:12 PM
RunRed
Jul 2, 2006 07:38 AM
zobie18
Nov 5, 2005 10:02 PM
