Door Chime
Old May 13, 2015 | 07:15 AM
  #61
CarlT100's Avatar
CarlT100
Originally Posted by shortride
Turn off Safety-Belt Chime
The driver and front passenger Belt-Minder feature can be deactivated by performing the following procedure.
Before following the procedure, make sure that:
* The parking brake is set
* The gearshift is in P (Park)
* The ignition switch is in the off position
* The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the on position. Do not start the engine.
2. Wait until the safety belt warning light turns off. (approximately 1 minute)
* Step 3 must be completed within 30 seconds after the safety belts warning light turns off.
3. For the seating position being disabled, buckle then unbuckle the safety belt 3 times, ending in the unbuckled state.
* After step 3, the restraint system warning light (airbag light) will be turned on for 3 seconds.
4. Within approximately 7 seconds of the light turning off, buckle then unbuckle the safety belt.
* This will disable the Belt-Minder feature for that seat position if it is currently enabled. As confirmed, the restraint system warning light will flash four times per second for 3 seconds.
Worked like charm. Thanks.
Old Aug 14, 2016 | 05:55 PM
  #62
BigBlueOx's Avatar
BigBlueOx
Originally Posted by skylinekw
I was surprised that if you shut the truck off with the key in the ignition and the lights on it still chimes, wich is good.
This is exactly what I want. The link doesn't work and the colors on my truck don't correspond. Does anyone have an update for newer trucks?
Old Aug 18, 2016 | 12:32 PM
  #63
BROWN DOG KTM's Avatar
BROWN DOG KTM
Very Helpful info on disabling the door open chime with key IN the switch :
https://www.ford-trucks.com/forums/1...-pictures.html
RDele
Aftermarket Products
Feb 5, 2018 04:34 PM
reptar0077
Dec 4, 2017 06:00 PM
sflem849
81
Feb 26, 2017 08:37 AM
EndorphinJunky
Ford Truck Parts for Sale
26
Jan 12, 2017 01:58 PM
