Installing Omega 1B-F1 p.a.t.s. bypass kit - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Reload this Page >
Old 01-15-2007, 05:50 PM
RDele
RDele is offline
RDele is starting off with a positive reputation.
I installed a remote start and I checked all features with key in the ignition. Everything works as it should.
Now I must install my Omega 1B-F1 pats bypass kit.
I need to know where to connect the wires from my kit to the truck wiring.
The kit harness has
brown- neg. ground when running
green- ecm-tx
blue - ecm-rx
violet - n/c
red - ignition
black - chassis ground
I see a white connector leading from the pats module with 4 wires in it.
white
blue
black
orange
I assume some of the wires get connected here but, which ones to where?
Thanks for your help
Old 01-17-2007, 05:57 PM
RDele
RDele is offline
The kit harness has
green- ecm-tx
blue - ecm-rx
violet - n/c
red - ignition
white
blue
black
orange
Thanks to anyone who looked at my post. I will answer my own post as I fixed my problem.
Follow the manufacturers instructions with the ecm wire hookups but, get your power from the remote start ignition wire and get the negative ground(when running) wire source from your remote start unit. I got mine from the anti-grind wire.
I'm told that using the ground at the p.a.t.s. module won't let your bypass kit receive the signal that it is suppose to receive.
Once everything was hooked up. The key was recognized by the kit. I took the key out and tried my remote start and it works perfectly.
I would be glad to help anyone with information that I have learned.
Old 01-22-2007, 10:52 AM
knix's Avatar
knix
knix is offline
knix is starting off with a positive reputation.
Smile
Thankyou for posting, I have a 2000 Expedition that i was thinking about tackeling a remote start on. I am encouraged by your sucess.
Thanks
Knix
Old 01-23-2007, 07:30 AM
RDele
RDele is offline
Thanks
Knix
I would be glad to help out in any way I can. Just e-mail me questions.
Old 02-05-2018, 05:34 PM
Shawn5005
Shawn5005 is offline
Shawn5005 is starting off with a positive reputation.
Are you still around? I have some questions about the Bypass colors which didnt get answered
Shawn5005
1997-2006 Expedition & Navigator
02-08-2018 07:06 PM
stirfrysteve
Ranger & B-Series
01-18-2018 04:42 PM
johnday
2009 - 2014 F150
07-24-2017 10:48 PM
Dan_Johnston
06-27-2017 08:44 PM
Psyclopse
03-14-2016 11:29 AM
Quick Reply: Installing Omega 1B-F1 p.a.t.s. bypass kit
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
