460 engine swap
Old Jul 13, 2010 | 07:53 PM
martion's Avatar
martion
460 engine swap
hi there im trying to do a 460 swap into my 77 f250. i have a 1988 460 with a 5 speed that i was going to use until i found out the heads wont work for putting a carbed intaked on. i have bought an older 1970s 460, i am wondering if i can just take the flywheel and harmonic balancer off of the 88 motor and run them on the 70s motor with no issues? i want to use the zf 5 speed trans. i am trying to do this as cheap as possible so im trying to use the parts i have already. thanks
Old Jul 14, 2010 | 08:13 AM
Blown 331's Avatar
Blown 331
What year 460 is the one from the 70s? Unless its a 79 the balancer and flywheel wont work. They changed the balance in 79. Your best bet might be putting the older heads on your 1988 engine.
Old Jul 14, 2010 | 11:35 PM
martion's Avatar
martion
not sure what the year is of the old one, everything i can find is that all 460s were internally balanced, never thought of swapping the heads tho.
Old Jul 15, 2010 | 08:43 AM
Blown 331's Avatar
Blown 331
68-78 is internally balanced. 79-97 is externally balanced.
Old Jul 15, 2010 | 09:27 AM
mark a.'s Avatar
mark a.
If both motors have the counter weights then your ok. Look behind the front damper.
OLDBLUEF250
Oct 22, 2016 08:42 PM
69 lil' Red Shane
Sep 2, 2016 09:03 AM
ralphatlarge
Dec 28, 2010 06:51 PM
mositso
Engine Swaps
13
Mar 7, 2010 07:30 PM
Mudman
Sep 18, 2006 09:41 AM
