Warning light threshold...
Old Jul 12, 2010 | 05:16 PM
CSIPSD's Avatar
CSIPSD
Tell me where you would like to see a "warning" light on a gauge set up...
Pyro...
Boost...
Tranny temp...
Oil temp...
Water temp...
Fuel pressure...
Oil pressure...
Exhaust back pressure...
Diff temp...
Volt reading...
Let me know what you think... got something coming I think...
Excuse the pic, crappy cell pic...
Old Jul 12, 2010 | 06:18 PM
CSIPSD's Avatar
CSIPSD
Hummm... 25 views and not one response...
You guys not getting what I am asking?
or just not interested?
Old Jul 12, 2010 | 06:28 PM
milleroutdoors's Avatar
milleroutdoors
Joe Tell me more. I would like to have a warning light when meeting a certain threshold. Isspro????
Old Jul 12, 2010 | 06:32 PM
WA.Ranger's Avatar
WA.Ranger
I think it's a real good idea. Not always paying attention to the gauges in the heat of the moment, that would get your attention.
megawatt00's Avatar
megawatt00
I am giessing that it is like a pre alarm condition. IE Pyro sets of a warning at 1200* Coolant at xxx* like that.
Old Jul 12, 2010 | 06:33 PM
superduty4x4's Avatar
superduty4x4
I have these things called eyeballs. They are my warning system
Pyro- I say 1200°
Boost- dependent on setup- 28psi for a stocker
Trans- 220°
Fuel pressure- <50psi
Old Jul 12, 2010 | 06:36 PM
CSIPSD's Avatar
CSIPSD
Thats what is being worked on... Michael and myself are running a few test subjects right now, but I am currious what you guys would want as preset warning thresholds...
Old Jul 12, 2010 | 06:42 PM
CSIPSD's Avatar
CSIPSD
Pyro- I say 1200°
Trans- 220°
Fuel pressure more then 50psi??? Or less then 50psi? A stock OBS with a mechanical fuel pump will see spikes and lulls below 40psi. Just trying to understand your thought process...
Good idea on the boost gauge...
Boost 0-30 would be at say 25 psi
Boost 0-40 would be at say 30-35psi?
Boost 0-60 would be at 40 psi...
Kind of go up as the boost does to step up as the mods do...
Mine is set at 35 psi right now to test the function, as I can hit that fairly easy.
Water temp is set at 190* as well. it was on most of the way from Bend to here...LOL
Old Jul 12, 2010 | 06:48 PM
big poppa's Avatar
big poppa
Its not a bad idea, wonder if a warning buzzer would be in there as well, just a thought.
Old Jul 12, 2010 | 06:53 PM
SpringerPop's Avatar
SpringerPop
How about a different sound alarm for each item monitored? That way, when you hear a particular sound, you know what gauge to look at.
Pop
CSIPSD's Avatar
CSIPSD
Problem with a buzzer... What if its something that may go off for a while... A pyro would be one thing, but a oil temp, or a water temp would **** you off on a hot day pulling a grade with a few horse...
Old Jul 12, 2010 | 07:05 PM
Franko72's Avatar
Franko72
Molon Labe
Yes....a buzzer on the pyro would be great,
My eyes are usually in the mirrors when I'm pouring the coal to her.
By the time I see the pyro, its coming down.
Old Jul 12, 2010 | 07:10 PM
CSIPSD's Avatar
CSIPSD
My eyes are usually in the mirrors whenI'm pouring the coal to her.
So a red light in your eyes would not get your attn??? LOL
How long can you drive looking in the mirrors without looking foward?
Old Jul 12, 2010 | 07:30 PM
F350-6's Avatar
F350-6
I'm interested Joe. The wife is looking for a different set of gauges. The other light up warning type gauges either seem too expensive or too cheap. Please keep me updated on these.
I'm not sure why you had ECT set so low. I've seen EOT running around 208 when empty on a warm day down in Texas.
Pop
If the light started flashing, you would look at the light, and therefore be looking at the correct gauge I would think.
Old Jul 12, 2010 | 08:07 PM
Franko72's Avatar
Franko72
Molon Labe
attn??? LOL
I'm sure a light would work also.......lol, I would need a bright one down here though.
Longer than I should. If you seen the way my boss loads our trailers, you would understand.
